Threads: 541
124
Anyone know how compatible the electrics would be if I were to swap a 99 hdi lump with its engine loom connecting to the car loom of my 98 xsi cabby at the near side front chassis leg and HDI dials plugged in?
Would it start, would I need the immobiliser mapped out the ecu?
Any other issues I wont of thought of?
Threads: 27
20
Yep 1 issue
It's a diseasel!! Lol
Threads: 202
58
You'll scrap it before you do it?
Threads: 189
10
Car Model/Spec: E39 ACS 535i
Given 2 thank(s) in 2 post(s)
Sell it, buy a ph3 then just swap the bay loom over.
Orr you could look for one of those very rare ph2 Hdis and have the bay loom from that.
Other option is ph3 loom the whole car, or try and work the wiring out in the multi plug under the wiper motor (pin position is different from ph2-3) main things are lights and speedo, everything else will work AFAIK
For the ecu, ignition on in the donor car then unplug the ecu, remove the box on the ph2 and no imob issues.
Threads: 541
124
Sorry Chris, which box on the ph2 do you remove?
Threads: 581
195
Scrap it. You will do soon anyway so might as well before you spend a load of money.
Threads: 189
10
one under the dash, same place as the ph3 ones
Threads: 581
195
Theoretically speaking, the only issue you may have is the glow plug light (do HDis have a glowplug light? Even still, they would only come on for a split second right?)
The body loom is basically the same. On ph3s and 2s, the clocks are interchangeable and fully work. As chris says, you may have to swap the bsi with the one that comes with the ecu.
So you need ECU, BSI and keys all from the same car. Oh and the vin incase you ever need to get your key code.
Threads: 189
10
ph2 and 3 looms are completely different Niall, the dials are interchangeable, but thats pretty much about it.
Imob and locking are different 100% so you cant just drop the ph3 stuff in.
Threads: 581
195
(25-04-2013, 07:19 PM)Chris Wrote: ph2 and 3 looms are completely different Niall, the dials are interchangeable, but thats pretty much about it.
In what way? The only ones that are different are the early ph2s where they dont have a bsi and have a locking unit behind the rear door card on a 3dr
Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
25-04-2013, 07:30 PM
(This post was last modified: 25-04-2013, 07:30 PM by HDIkyle.)
The BSI connections are different between Phase 2 and 3. I had this problem when fitting a phase 2 gti engine to a phase 3 shell. Had to get the ECU unlocked and cut 3 wires from the engine loom. I would think it would work the same going from petrol to diesel however
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 189
10
All ph2's are like that, none have the bsi unit like the ph3s
Threads: 581
195
(25-04-2013, 07:33 PM)Chris Wrote: All ph2's are like that, none have the bsi unit like the ph3s
Ive seen them in ph2s under the dash but then again they could of been 2.5s and god only knows what parts went into them. Even still, if he has to do a full loom change, its hardly difficult tbh.
Threads: 541
124
I have a feeling mine should have a bsI and you say about interchangeable of looms but decs ph2 engine loom plugged straight into jjs ph2 hdi and started fine
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
Threads: 198
135
(25-04-2013, 06:12 PM)Dum-Dum Wrote: Anyone know how compatible the electrics would be if I were to swap a 99 hdi lump with its engine loom connecting to the car loom of my 98 xsi cabby at the near side front chassis leg and HDI dials plugged in?
You'll still look like a hairdressing rainman?
Threads: 541
124
Anyone have any more thoughts on this?
Threads: 27
20
(26-04-2013, 02:33 PM)Dum-Dum Wrote: Anyone have any more thoughts on this?
Yep!! Don't do it lol
Threads: 465
114
Car Model/Spec: Vauxhall
you will never get it finished
Threads: 163
53
Car Model/Spec: 406 HDI
Wouldn't fancy a coaly derv with the roof down myself...
Threads: 18
3
Threads: 10
3
Car Model/Spec: GTI-6
26-04-2013, 06:26 PM
(This post was last modified: 26-04-2013, 06:27 PM by Puggie.)
A cabby derv thats smokes its tits off awesome
Threads: 541
124
Just have to go fast enough the smoke cant catch you lol.
It's the reason I want a hdi as there should be alot less smoke.
Threads: 10
3
Still Devils fuel v6 it for shits and giggles
Threads: 183
20
Given 8 thank(s) in 8 post(s)
Do it do it do it do it dooooo it
Threads: 141
35
i think a cabby gti would be better than hdi. finish your plans that were in place for your bianca 6 before its "incident" i.e. cammed and throttle bodies. epic bwarp with no roof
Threads: 581
195
(26-04-2013, 08:20 PM)ozonehostile Wrote: i think a cabby gti would be better than hdi. finish your plans that were in place for your bianca 6 before its "incident" i.e. cammed and throttle bodies. epic bwarp with no roof
Have you never realised that dum dum never finishes projects. He never even finishes thinking up projects before he scraps them!
Threads: 141
35
i don't know, he is getting better, at least with the sedan it actually got the engine change before he sold it haha
Threads: 541
124
Yeah Im not a fan of useful cars that work properly
Threads: 465
114
