	Threads: 110
20 Location: Devon
       Thanks: 1Given 30 thank(s) in 30 post(s)
		So the S16 i brought the other day seems to have had a boost valve fitted. 1 like this http://www.ebay.co.uk/itm/350230965032?s...300wt_1018
I was just wondering if anyone has any experience with these and is it worth putting it on to mine
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		No.
These sort of things are crap. I played about with the rail pressure on my 1.8 a bit and had no end of troubles. The ECUs are just not advanced enough to adapt so it just throws a shit fit. Leave it be mate
	Threads: 110
20 Location: Devon
		Ok cheers might chuck it on ebay some time
	Threads: 110
20 Location: Devon
		Has anyone ever fitted 1 of these to there car?
	Threads: 106
7 Location: Manchester
 Car Model/Spec: GTi-6
		I run one on mine, but it's too help fuelling with the cams I'm running... You need a remap ideally otherwise it'll totally ruin your air/fuel ratio.
 JP
JP
	Threads: 110
20 Location: Devon
		 (21-04-2013, 04:52 PM)jammapic Wrote:  I run one on mine, but it's too help fuelling with the cams I'm running... You need a remap ideally otherwise it'll totally ruin your air/fuel ratio.
 JP
Ok cheers. When i drove the car which had it on i didn't think it went that well. Do you know if S16 ECU can be remapped?
	Threads: 33
2 Location: Shrewsbury
 Car Model/Spec: 306 D-turbo/306 Rallye
		Bit of an old thread but there is one of these fitted on my
Rallye, was on there when I got the car, no Idea if it helps or anything because I've never been in another 6/rallye, car does go quite well though!
Blaze '6 and Blaze D-turbo!
		put it back to a standard FPR mate. If it hasnt been mapped in, it will only do damage in the long run.
	Threads: 110
20 Location: Devon
		Dont think i am ever going to make use of it so is anyone interested in the boost valve? ![[Image: null_zps25394b54.jpg]](http://i1065.photobucket.com/albums/u388/nufc4frosty/null_zps25394b54.jpg)
	Threads: 465
114 Location: Cullompton Devon
 Car Model/Spec: Vauxhall
     Thanks: 1Given 98 thank(s) in 92 post(s)
		oww an ajustable FSE valve have you the blanking plug for the fuel rail too?
	Threads: 122
9 Location: south west, devon
 Thanks: 1Given 7 thank(s) in 7 post(s)
		He has the full kit off the car he broke
	Threads: 110
20 Location: Devon
		I've just got the valve and some pipping that's in the pic. Also got some instructions that come with the car. If anyone wants if £10 and it's yours
	Threads: 465
		there should be a blank take off that fixes into the rail where the original fpr fits
	Threads: 110
20 Location: Devon
		There is a bit that goes to the rail I think but it has a pipe going to it. I don't really have any knowledge of these things
	Threads: 465
		you need this bit or its pritty useles for the 6
	Threads: 122
		It was on the car when he drove it back from chard im 100 percent he has the whole kit
	Threads: 106
		FYI, you need a remap to go with one of these... without it, the AFR will be totally ruined and you'll either run rich and wash the bores out, or lean and kill the motor.
 Only safe to use with a fully custom remap set up on the dyno or the road.
JP
	Threads: 110
20 Location: Devon
		 (22-06-2013, 07:23 AM)cully Wrote:  you need this bit or its pritty useles for the 6
I've got that bit if its the same size for a 6 as a S16
 ![[Image: null_zpsa85febb7.jpg]](http://i1065.photobucket.com/albums/u388/nufc4frosty/null_zpsa85febb7.jpg)
	Threads: 33
		25-06-2013, 07:28 PM
(This post was last modified: 25-06-2013, 07:29 PM by Mitch.)
		So does anyone have a standard one i could buy then? i have no idea if the car has been mapped or anything, it certainly does shift very well though and it runs spot on
