	Threads: 6
 Car Model/Spec: 306 HDI 90BHP
		16-04-2013, 04:08 PM
(This post was last modified: 16-04-2013, 04:08 PM by moonstoneblue.)
		i was just wondering would the straight diesel xud be able to take a turbo as want to start a project but don't want to convert an engine its just for a bit of craic for a feild car as its a little low on power
	Threads: 164
 25
 Car Model/Spec: Gti6
	Given 4 thank(s) in 4 post(s)
		From what i remember they arent built as strong but i may be talking rubish
	Threads: 6
		so would just probably better off getting a dt engine and converting it
	Threads: 56
 19
 Car Model/Spec: Moonstone HDi
	Threads: 119
 Car Model/Spec: MG ZS180
		Engine swap can be done in a day quite easily anyway.
	Threads: 141
 35
		Nad engines have different piston compression ratios, injectors and manifolds. Dont bother wasting your time, just drop a cheap xud9te in, way easier
	Threads: 41
 Car Model/Spec: Dtractor
	Given 6 thank(s) in 6 post(s)
		If this is just a field car for lols then bang a blower on it! Wack your nad fuelling right up, will need to find an oil feed though
	Threads: 129
 11
		I'm with Dave here, whack on a blower, if it blows then it would just be scrapped anyway so you may aswel make use of it.
Stage 2 XUD Sedan
	Threads: 143
 10
 Car Model/Spec: Ph3 XUD
	Given 8 thank(s) in 8 post(s)
		I had a thought the other day, NAD's have higher compression right?
Surely that would mean you'd just run less boost? Obviously if the other parts like rods and pistons aren't as strong at DT ones it going to end badly.
	Threads: 41
		bit of a crack for a field car sums this up though...
	Threads: 19
 Car Model/Spec: Ph1 D-turbo(on going project)
		funnily enough i can imagine it being less work to swap engines than trying to put an engine on an na....
	Threads: 41
		yeh but you wont need to connect up stuff properly, IE turbo return back to the filler neck, and if you didnt wanna bother with an exhaust etc you could do it in half a day
	Threads: 6
		cheers for the advice going to put a turbo on and wait to it goes bang as can get a dt engine for 100 off a mate to put in to it went it goes
ps fuel is out 1 turn and a half on a lucus
	Threads: 41
		16-04-2013, 07:20 PM
(This post was last modified: 16-04-2013, 07:20 PM by Dave.)
		haha get a bosch on it,
on a totally unrelated note, I saw this thread title and instantly thought of the song 'put a donk on it' but obviously 'put a turbo on it' is just so much more win..
		ozone is selling some HUGE turbos......defo should be done
	Threads: 6
		the straight finally kicked the bucket and im wondering how hard it would be to drop a dturbo in it is there much difference in the wiring and what would need to be changed
rip straight d
	Threads: 141
 35
		no electrical differences atall, the engine will drop straight in (unles you put a massive turbo on the back)
	Threads: 6
		great job will give me and a few mates a job to do at the week end
thanks for your help
