key fob
can any one advise,my car seems to have immobilised itself,took said key into an auto shop the guy put key into machine then told me there was no transponder in the fob,would this cause car to immobilise itself.Huh
Yes, the ignition barrel you put the key into has to detect a transponder in the key fob before it lets you start the car. I think.
What year engine car etc?
(13-03-2013, 04:04 PM)Tom Wrote: Yes, the ignition barrel you put the key into has to detect a transponder in the key fob before it lets you start the car. I think.
cheers tom for quick reply 2000 reg 1.6 petrol pug meridian
Im not to clued up on the petrols really, most cars do have a little chip (transponder) in the key that matches the to the ignition barrel to let you start the engine. Have you just bought the car or something? Or did it just stop working one day?
(13-03-2013, 04:20 PM)Tom Wrote: Im not to clued up on the petrols really, most cars do have a little chip (transponder) in the key that matches the to the ignition barrel to let you start the engine. Have you just bought the car or something? Or did it just stop working one day?
bought car in october last year it was running gr8 till that happened.
so where have you lost the chip?
have you taken the key fob to bits before you couldnt start the car?
have you a second key?
(13-03-2013, 06:29 PM)cully Wrote: so where have you lost the chip?
only one key,thought fob needed new battery so opened fob to replace battery so i must have lost it then,would that be the cause for car not starting.cheers m8
Ye defo mate no chip no start.
Hdi decat midlebox mod soon to be stage1Itwasntme
yep no chip no start!
you need to go to the place you changed the battery and check the floor
the chip is a small black thing with no legs and it is pushed into the key fob case
good luck on finding it !
see here in the top corner of the picture
[Image: DSCF0056.jpg]
(13-03-2013, 09:40 PM)Hdiestate Wrote: Ye defo mate no chip no start.
cheers for your response m8,i was told if i went back to auto shop with the logbook or the vin number they would get transponder and code for key,would that be enough or would they have to program the the car.cheers again m8
ThumbsUp
car would have to go to to be coded
be prapared to get robbed by peugeot
oh do you have the security pass code?
(13-03-2013, 10:31 PM)cully Wrote: yep no chip no start!
cheers cully,no chance of finding it in my gardenThumbsUp
I dont know about pugs but renaults u can change the ecu bsi and then just
Change the blade over in the key.
It might be cheper than going to peugeot. Last 1 i done at work was a clio i got the lot for £80.
