		Well, not throttle since diesels don't have a throttle, but you know what I mean. Also, possibly not an XUD, not sure what the proper name is for a 1.5nad, but it's not a petrol or an di electrical nightmare, so thought i'd put it in here. Basically my 106 has issues with working out what power I want when I keep the accelerator partially depressed - it will surge and hesitate at random, sometimes changes the idle speed, minor flat spots at WOT. Anyway, video probably explains better:
Further info:
Possibly, but not necessarily, related problems - starts on 2/3 cylinders when cold and has cut out once or twice shortly after starting for the first time of a day, problem is also much worse when it's very cold or has been sat for a long time. Thoughts on possible causes were glow plugs, sticky injectors or air's getting into the fuel somewhere. Maybe a combination of a couple, or even all three, who knows... Well, hopefully one of you, so...
	Threads: 87
 31
		FYI its a TUD    My guess would be air getting in tbh, explains the bad starting, flat spots etc.
 81
		yep and there was a rally version used in the pro championship which was a TU Racing D
		Yeah, air getting in was my main thought, any idea of most likely culprits? Fuel grenade, injectors, tank pick-up?
Tbh I like it when it surges, briefly feels like it's got good power lol. Can't imagine this thing racing anywhere, not for lack of trying though
		No guesses then, bugger. It's started cutting out now, is getting worse by the day. Just haven't got time to fix it with everything else going on. :S
	Threads: 541
 124
		Air in fuel or a clogged fuel filter
	Threads: 465
 114
 Car Model/Spec: Vauxhall
		my 106 NAD sounded the same
the reason i found was
pick up in the tank was blocked also the filter was blocked on a second time .was due to running high fat content veg oil
	Threads: 92
 43
		  @ your commentary "wtf is all that about"
		Might just take the filter out then, sod it. Once the HDi is back the nad-wagon will be getting boosted, ragged and killed, all in the space of a week, so it's not like it needs a new filter.
	Threads: 7
		Spray brake cleaner or wd 40 over injectors and anywhere sort of fuel related wen on idle if it has a air leak shell pick up on revs then uv found ur leak..
		Ah good tip, will try that tomorrow, cheers.
Will have a look at the filter, pick up and grenade too and see what i find.
	Threads: 9
		Mine has a similar issue, but only after I've been full throttle such as at a junction. In 5th gear flat out you don't notice it but from 2nd to 3rd you definitely get some form of surging for about 5 seconds. The throttle feels a lot more sensitive for that period, it's really strange. I'm going to change the fuel filter this weekend if I get chance as I had her cut out randomly on the motorway for 5 seconds yesterday.
Previous Car: Peugeot 306 XLdt (stock!), 150,000 miles (I miss this car   )
