What does this sound like?
Of course that's the problem... will never run right with a Lucas injector
Has it allways had that problem tho?
[Image: blazejpg1.jpg]
Connor Wrote:Of course that's the problem... will never run right with a Lucas injector
Really? i thought they'd still run, just under a lower pressure?
hm this makes me think...
If you listen carefully.....sounds just like a golf! :o
Yeah Lucas injectors "work" but won't be right
Connor Wrote:Yeah Lucas injectors "work" but won't be right
but would it create that sound? am i getting that sound right - air blow sounds like??
It never did it with Lucas and only does it when it gets warm hopefully ill see what happens when I get a Bosch injector in there
Ive got 4 lucas injector on my bosch pump. My mate did what you have done but he had 3lucas and 1bosch and it sounded same change injector too bosch job done
[Image: mintsig.jpg]
STAGE2 XUD DEAD ATM ENGINE REBUILD
GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM
COMING SOON TD04 Big Grin
Either run bosch or lucas, both will work, but you cant mix them up...they break at different times, so timing is all over the place.....
[Image: sigi-2.png]
Right cracking! Ill get it sorted! Thanks for the help guys!
