Is it true
That the gti-6 6 speed box fits these as I've been told it will
Yes, but the ratios are far too short for normal use. Depends what you want it for... Economy, then no.
Even with 6th gear?
Surprising!
It's a close ration box... the 6th gear is no longer, they're just closer together
6th at governor is about 105
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Yep, tried and tested.
And I turned the gearbox oil silver in 2000 miles, the diffs in them apparently don't like 300+lbft torque... And made the synchro on 3rd disappear...
And 3700rpm ish at 70mph... And a 105mph limit at around 5300 if you're govmodded... Trust me, if you do ANY more than 10 minutes a month at 60+, you'll want rid of it.
Just because they're 6 speed, they aren't any longer, they're actually shorter overall than most of the 5 speed boxes!
Oh right thanks guys ill look out for a dtub box or hdi box near me then thanks fellas
Or you can try a 405td box as its sposed to be a good compromise between the Hdi and 306 Dtub box
I have a hdi box if you are interested £40 Smile
(10-12-2012, 01:33 AM)ash240970 Wrote: Or you can try a 405td box as its sposed to be a good compromise between the Hdi and 306 Dtub box
an hdi box would defiantly be your best bet if you want good economy, ive always felt that for a big family car, i.e long distance motorway cruising etc, the 405 gear box could do with a much longer 5th, just seems to run out of puff a bit quick, always think it would be so much better with a really long 5th or a 6th gear. just a shame that 6 speed dervs didnt really exist until about 2003 so not much chance of getting a 6 speed derv box to fit an old xud Sad
I just wondered cos me old man has a ford galaxy diesel with a 6 speed box and its great at motorway speeds
if you changed to an hydraulic clutch i'm sure the 6 speed dervs use a be3 housing. they certainly look similar
Nothing like sadly, they're an ML series box, you'd have to adjust the subframe, bulkhead and chassis leg to fit.... And it's hydro clutch...
