27-11-2012, 05:33 PM
Not a Peugeot, but it could be if you close your eyes and squint really hard..
Picked this up from Curt a few months ago when I got rid of the '6.
It needed (and still does) a lot of TLC, but I won't let that get in the way.
Went through the MOT 2 hours after picking it up and needed 4 new tyres (420 quid for budget tyres FUUUUUUU).
![[Image: 39C1DB2B-D26B-451C-8D60-7965E721CBE9-687...94EA03.jpg]](http://i1162.photobucket.com/albums/q534/vlj91/39C1DB2B-D26B-451C-8D60-7965E721CBE9-6870-000002CFD194EA03.jpg)
![[Image: A9E656F8-AD57-4DA1-9249-64B7D6BCF379-687...C921EB.jpg]](http://i1162.photobucket.com/albums/q534/vlj91/A9E656F8-AD57-4DA1-9249-64B7D6BCF379-6870-000002CFDCC921EB.jpg)
![[Image: 4F09275E-BDCA-4B39-A36F-505E850CD09A-687...08EE4C.jpg]](http://i1162.photobucket.com/albums/q534/vlj91/4F09275E-BDCA-4B39-A36F-505E850CD09A-6870-000002CFD808EE4C.jpg)
Wasn't really sure what I wanted with the thing for a while then I killed the clutch.
Went for the VR6 pressure/friction plate as they seem to be a good match and are rumoured to hold around 400BHP should i so wish.
Haven't been very good at taking pictures throughout this sadly though..
Also replaced the diverter valve, much smoother through gear changes and a lot less lag.
![[Image: 4E55F326-E5BF-47C9-AFDF-FB9CFC1CD328-687...B5A5A5.jpg]](http://i1162.photobucket.com/albums/q534/vlj91/4E55F326-E5BF-47C9-AFDF-FB9CFC1CD328-6870-000002CFE1B5A5A5.jpg)
http://s1162.beta.photobucket.com/user/v...sort=3&o=1
Of course, being me this didn't go without injury.
![[Image: 026F2E19-9787-4D99-B708-6CC11DB7B8F9-687...503408.jpg]](http://i1162.photobucket.com/albums/q534/vlj91/026F2E19-9787-4D99-B708-6CC11DB7B8F9-6870-000002CFEB503408.jpg)
It's a lovely car to drive especially for it's age/mileage (180k), but I still wanted more..
Haven't got any photos so a fairly boring update, buuuuut:
Went to go and get a stage 1 chip (195bhp+/-, probably a lot less knowing my luck), absolutely transforms the drive and amazingly economy has increased at cruise speeds too (thank f*ck).
However whilst the stage 1 was all well and good, the standard setup is rather restrictive so I ended up with:
- Forge TIP
- 3" downpipe & decat
and a forge 007p with cold side relocation like this..
![[Image: DSCF1093-1.jpg]](http://i1162.photobucket.com/albums/q534/vlj91/DSCF1093-1.jpg)
Again, not just a placebo you can absolutely feel the effect the restriction on the standard intake pipe is unreal, the L bend before the turbo completely bottle necks you.
As the AGU engine is relatively strong and has been shown numerous times to support in excess of 350BHP and maintain reliability I wanted to play around with some more power.
I've been looking into various turbo set ups..
The K03s is pretty much a like for like just bolt it straight in and you are good to go - injectors are probably an idea but the standard ones should work for you up to about 240bhp.
At those sort of figures your going to be putting a lot of strain on the turbo, and I'm looking for reliability.
The K04 seems the other most common choice however there is an issue with the conversion: manifold (no one currently produces a manifold that doesn't split and crack as soon as you get it hot.
I've got a K04 to go in but currently toying with going for a cheap Chinese option. You can pick up these on eBay http://www.ebay.co.uk/itm/400307878886?s...64&afsrc=1
![[Image: %24T2eC16V,!y0E9s2S65DEBQkp1OPtTg~~60_12.JPG]](http://i.ebayimg.com/t/AUDI-A3-S3-1-8T-20V-T3-TURBO-MANIFOLD-WASTEGATE-TURBOCHARGER-/00/s/MTA3MVgxNjAw/%24T2eC16V,!y0E9s2S65DEBQkp1OPtTg~~60_12.JPG)
A few members on ASN have run these at 330-350 BHP reliably and consistently and it is pretty much a bolt in job and done.
Hoping to get the new turbo set up sorted & in after Christmas.
Cheers!
/awaits abuse for having the wrong car
- Forge TIP
Cheers!
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg)
well yes, both of those. But the turbo would be better for power
![[Image: fe6eddc8-1731-4100-a5fe-1edb853a88b6_zpseeacf928.jpg]](http://i1236.photobucket.com/albums/ff441/big543/fe6eddc8-1731-4100-a5fe-1edb853a88b6_zpseeacf928.jpg)
