Xud decat
Does anyone do one for a non turbo and what's the legality of doing it
XUD's don't need cats as they were made before they were compulsory. Also XUD's need only pass a smoke test at the MOT.
Mines a 97/98 r reg does it not have a cat then 1.9 non turbo
Whats the point of a decat on a N/A? not like its built for power
Just thinking saves the cost of a cat a de cat pipe gotta be cheaper than a cat
just ask the motor factors for a down pipe for a 94 straight diesel, i dont see why a TD pipe wont fit tho
Will that just bolt up to my exhaust then and does mine have a cat or not ?
it will bolt straight on but get a new fitting kit and clamp. only way to know if yours has got a cat is to look under it
Ill do that tommorow I thought that any car manufactured after a certain year had to have one 1992 stands out for some reason
well a 94 TD dose not have one as standard, and diesel cars have not got cat's there particle filters.
Oh right my bad I don't know much about diesels this will become more and more evident the longer I'm on here
(13-11-2012, 08:48 PM)Daniel306 Wrote: just ask the motor factors for a down pipe for a 94 straight diesel, i dont see why a TD pipe wont fit tho
Because TD's have turboz and shit?
Yea, but i still think the flange will fit, just the pipe may be slightly larger
I was thinking more the length of the downpipe part of the cat, like a gti6 won't fit an xsi as the mani is different.
I think they are about the same length, on the TD there is the turbo but on the N/A there is the honey come manifold thing
Whilst diesels are only tested on particulates, most made in the last 15 years do have cats, and as of January 2012 any car fitted with a cat from the factory must have one present at the time of MOT. However I'm not convinced they can reliably tell, and it's not too difficult to find a sympathetic mechanic Wink
My mot tester is to be the best man at my wedding known him 23 years lol
NAD have different diameter pipe. I had a straight through mid pipe from one once thinking it was for a DT, wouldn't fit with my DT de-cat.
So does anyone know to a de cat/ particle filter for a NA diesel estate
chop it out and weld in a straight pipe. job done.
Ill have to find someone near me with a welder then
http://www.ebay.co.uk/itm/EXPG2003-PEUGE...1c21c33fe2
That's local to ill have to give them a ring thanks
NAD's also have a different shape downpipe. You CAN get decats pipes though. Been there done that Smile ... Makes a difference too with a bit of extra fuelling.
[Image: KrisB-new-Logo11.gif]
Where would I get a de cat is it best to just try and get one made and how would I alter the fueling
Follow the turbio diesel tuning guides, obviously you wont have a boost compensator or boost though.
Just phone round your local motor factors and ask for a downpipe for a '93 306 1.9D without cat.
Ok cool thanks for the help
