Xud decat - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Xud decat (/showthread.php?tid=7934) |
Xud decat - Willo - 13-11-2012 Does anyone do one for a non turbo and what's the legality of doing it RE: Xud decat - cwspellowe - 13-11-2012 XUD's don't need cats as they were made before they were compulsory. Also XUD's need only pass a smoke test at the MOT. RE: Xud decat - Willo - 13-11-2012 Mines a 97/98 r reg does it not have a cat then 1.9 non turbo RE: Xud decat - Daniel306 - 13-11-2012 Whats the point of a decat on a N/A? not like its built for power RE: Xud decat - Willo - 13-11-2012 Just thinking saves the cost of a cat a de cat pipe gotta be cheaper than a cat RE: Xud decat - Daniel306 - 13-11-2012 just ask the motor factors for a down pipe for a 94 straight diesel, i dont see why a TD pipe wont fit tho RE: Xud decat - Willo - 13-11-2012 Will that just bolt up to my exhaust then and does mine have a cat or not ? RE: Xud decat - Daniel306 - 13-11-2012 it will bolt straight on but get a new fitting kit and clamp. only way to know if yours has got a cat is to look under it RE: Xud decat - Willo - 13-11-2012 Ill do that tommorow I thought that any car manufactured after a certain year had to have one 1992 stands out for some reason RE: Xud decat - Daniel306 - 13-11-2012 well a 94 TD dose not have one as standard, and diesel cars have not got cat's there particle filters. RE: Xud decat - Willo - 13-11-2012 Oh right my bad I don't know much about diesels this will become more and more evident the longer I'm on here RE: Xud decat - cwspellowe - 13-11-2012 (13-11-2012, 08:48 PM)Daniel306 Wrote: just ask the motor factors for a down pipe for a 94 straight diesel, i dont see why a TD pipe wont fit tho Because TD's have turboz and shit? RE: Xud decat - Daniel306 - 13-11-2012 Yea, but i still think the flange will fit, just the pipe may be slightly larger RE: Xud decat - cwspellowe - 13-11-2012 I was thinking more the length of the downpipe part of the cat, like a gti6 won't fit an xsi as the mani is different. RE: Xud decat - Daniel306 - 13-11-2012 I think they are about the same length, on the TD there is the turbo but on the N/A there is the honey come manifold thing RE: Xud decat - ally406 - 13-11-2012 Whilst diesels are only tested on particulates, most made in the last 15 years do have cats, and as of January 2012 any car fitted with a cat from the factory must have one present at the time of MOT. However I'm not convinced they can reliably tell, and it's not too difficult to find a sympathetic mechanic
RE: Xud decat - Willo - 14-11-2012 My mot tester is to be the best man at my wedding known him 23 years lol RE: Xud decat - bigcheez2k3 - 14-11-2012 NAD have different diameter pipe. I had a straight through mid pipe from one once thinking it was for a DT, wouldn't fit with my DT de-cat. RE: Xud decat - Willo - 14-11-2012 So does anyone know to a de cat/ particle filter for a NA diesel estate RE: Xud decat - samass - 14-11-2012 chop it out and weld in a straight pipe. job done. RE: Xud decat - Willo - 14-11-2012 Ill have to find someone near me with a welder then RE: Xud decat - Daniel306 - 14-11-2012 http://www.ebay.co.uk/itm/EXPG2003-PEUGEOT-306-1-9-Exhaust-Front-Down-Pipe-/120825528290?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c21c33fe2 RE: Xud decat - Willo - 14-11-2012 That's local to ill have to give them a ring thanks RE: Xud decat - KrisB - 15-11-2012 NAD's also have a different shape downpipe. You CAN get decats pipes though. Been there done that ... Makes a difference too with a bit of extra fuelling.
RE: Xud decat - Willo - 15-11-2012 Where would I get a de cat is it best to just try and get one made and how would I alter the fueling RE: Xud decat - KrisB - 15-11-2012 Follow the turbio diesel tuning guides, obviously you wont have a boost compensator or boost though. Just phone round your local motor factors and ask for a downpipe for a '93 306 1.9D without cat. RE: Xud decat - Willo - 15-11-2012 Ok cool thanks for the help |
