Ph1 and ph3 doors
Are the the same? Other than the rubstrips?
No. The door card mounts are different but can be changed to fit
Rubstrips have the same holes, as springs said, only difference is how the door cars mount. Not that you can get moonstone in Ph1 whistle
My friend has ph1 sigma doors, with s16 door cards, which I planned on fitting to mine, but as I may have broke my drivers door today, just going to spray the ph1 doors and fit them lol
1. how did you break the door?
2. arent the rubstrip indents taller as the ph1 trim is taller?
Yes the trim is very different, but the holes are the same (except the wings, see pics of my Ph1.3 to prove this...)
basicaly yes, with the door you already as a donner it can be done very easily
Connor Wrote:Yes the trim is very different, but the holes are the same (except the wings, see pics of my Ph1.3 to prove this...)
+1
Superglue ftw whistle
arn't the rub strips width different dependent on the model - i know between my 1.4 and dturbo they were different...
Door panels are identical regardless of rub strips, only change as said is the mounts, but 5 mins job to change with drill and rivots Smile
[Image: sigi-2.png]
darrenjlobb Wrote:Door panels are identical regardless of rub strips, only change as said is the mounts, but 5 mins job to change with drill and rivots Smile
hm weird why my strips were different? :think:
i might get a pic of it... i thought they were the same until phil (4waydiablo) pointed it out to me i think, up at cheddar.
The actual trims are different ginge, but the holes they go into are not
Mounts inside or out? Door card or sidestrips? If its the door card I don't mind as I'll use ph1 door cards lol
Are my posts invisible? lol
Right so the gap for rub strips are different sizes :/ but hinges are the same
No... the door are EXACTLY the same, EXCEPT from the mounting points for the door cards
Okay thats awesome, cheers guys. Just take me a little longer to get as I'm thick haha
Connor Wrote:No... the door are EXACTLY the same, EXCEPT from the mounting points for the door cards
Ok, im going to get a picture of this tomorow and show you the differnce in sizes of my rubstrips on the OUTSIDE of my car....
Omg ginge... I know the rub strips are different, but the holes you push them into are the same...
ginge191 Wrote:arn't the rub strips width different dependent on the model - i know between my 1.4 and dturbo they were different...
Im talking about the ACTUAL strips - as i said in my first post - THE WIDTHS CAN BE DIFFERENT ...
(as in the width of the ACTUAL strips)
So when he's looking for a new door, if he needs the same width to be aware of this...
and a picture to tell you what i was on about..
[Image: q9zdj.jpg]
No ginge, he just has to take the rub strip off his current door and fit to the new door... THE HOLES ARE THE SAME... I never said the rub strips are the same...
