	Threads: 164
25
Car Model/Spec: Gti6
	Given 4 thank(s) in 4 post(s)
		Got home to find between me switching off the engine and starting it 5 minutes later its decided it doesn't want to idle and just stalls whenever its started with no throttle
any easy to check reasons for this ?
	Threads: 448
51
		Icv. Either take off clean up and refit. Or take the battery off for 20mins and do an ecu reset.
	Threads: 164
25
		Just been out and now its decided to start and run fine will clean the icv tomorow as i know its a bit rough
	Threads: 448
51
		Makes sure its all sealed properly and you should be fine. They can be really temperamental
	Threads: 164
25
		Will check it all over then also sounds like there's a ticking that sounds like its coming from cambelt sort of area but there's no pattern to the sound will try and get a video later
	Threads: 448
51
		May be something caught up in there? Or one of the pulleys/tensioners making a tick
