silly gti won't idle - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: silly gti won't idle (/showthread.php?tid=7164) |
silly gti won't idle - rocker8742 - 19-10-2012 Got home to find between me switching off the engine and starting it 5 minutes later its decided it doesn't want to idle and just stalls whenever its started with no throttle any easy to check reasons for this ? RE: silly gti won't idle - Matt - 19-10-2012 Icv. Either take off clean up and refit. Or take the battery off for 20mins and do an ecu reset. RE: silly gti won't idle - rocker8742 - 19-10-2012 Just been out and now its decided to start and run fine will clean the icv tomorow as i know its a bit rough RE: silly gti won't idle - Matt - 19-10-2012 Makes sure its all sealed properly and you should be fine. They can be really temperamental RE: silly gti won't idle - rocker8742 - 19-10-2012 Will check it all over then also sounds like there's a ticking that sounds like its coming from cambelt sort of area but there's no pattern to the sound will try and get a video later RE: silly gti won't idle - Matt - 19-10-2012 May be something caught up in there? Or one of the pulleys/tensioners making a tick |
