09-10-2012, 10:47 AM
Is it a big job to change a boot lid from phase 2 to phase 1? Where do you disconnect the wires going into it is there a plug? Thanks
Changing boot lid
09-10-2012, 12:11 PM
The wires are different between the phases so I don't think its a straight fit but wires all plug in under the plastic covers in the boot. Then just pull tho the holes and 4 bolts to remove.
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead
Should be fairly straight forward. Open the boot and in the top left and right there will be a rubber bung with wires coming out. You will need to pull these out. Then take the back end off the head linner off and the plugs should be behinde that IIRC. Unplug then and feed them out where the bumg was. Swap the boot lids over and do the same in reverse simples
![]() @ kyle. Not sure how unplugging them behinde that bit of plastic would help take the boot lid off. You need to unplug the from the top. When i swaped from ph2 to 3 i didnt touch the cover behine the lock. |
