Threads: 171
46
The struts come off by wedging a screwdriver in the metal clip at each end of the strut to pop it off
Obv the hinge is just 2 bolts
Threads: 171
46
The 4 clips along the top as well as it being held into place by the hockey sticks will hold it in place just fine
Threads: 37
Them 4 clips are destroyed lol. They wouldn't come out so pulled em apart with pliers
Threads: 171
46
Did you take them out correctly? You wedge a screwdriver in the top smaller head and the bottom larger head of the stud type thing then pull the top smaller part out and the larger bottom part is just as simple
Threads: 37
They were just push in clips. Like the ones holding on rub strips. Couldn't get em out at all do pulled em apart with pliers and pushed the bottoms thru the hole
Threads: 171
46
Yeah that's what they look like but they're like T shaped one inside the other. If you pull the smaller one out then the larger one just falls out pretty much
Threads: 37
I don't really get what ya mean pal. It was all one piece. Couldn't get underneath the clip to try push it thru as slam panel goes like all the way round. Was no chance of pulling a clip apart like your saying as I was using pliers, pulling at the circle an bits were ripping off before it came apart?
Threads: 208
60
You need to get either side of the the little push in bit.where as you were tugging at one side. Which allways rips them off.
Ebay : plastic push rivets and get some new ones. Thats all mine is held in with
Threads: 96
Cable ties FTW that's what unused for my smooth grill seems to work fine
Threads: 37
Cable ties lol
And ye they weren't like that mate. Couldn't get at either side of the clip as what they are pushed into, you can't get underneath to push each side in
