	Threads: 17
		Hi all
got a ph3 estate, the hdi lump has done 175k, overdue a service/cambelt and now the clutch is slipping.
I have been offered a cheap xud running a bosch, new cambelt, new clutch and bolted to a hdi gearbox, how easy will this be to fit?
cheers all
	Threads: 0
45
		I did it, easy swap.
If you look far enough back through my threads you'll see my project thread which might have details.
	Threads: 371
29
Car Model/Spec: ford fiesta
		Easy swap. Specially if you have the xud loom.
		The most difficult bit is probably getting the dvla to change the v5 to the correct details lol.
	Threads: 122
9
	Given 7 thank(s) in 7 post(s)
		Ive also done it, look through my old project threads
Essentialy though,  swapped engine and loom
Exhaust downpipe, radiator,  clutch cable, use some ph2 dash clocks,
	Threads: 136
11
		I'm thinking of doing this myself.
Regards to fuel lines, I know you have to swap the pump to the dturbo pickup. Do the fuel lines fit the same?
Why do you suggest phase 2 clocks?
I was thinking of getting the level sender working.
One last thing... Central Locking, will this be affected?
	Threads: 0
45
		Swap the in tank to dt pickup, fuel lines will fit fine.
Ph2 clocks are the only ones that straight away plug & play, you can leave ph3 in but your revs won't work.
Locking is fine.
You just plug the DT loom in on the passenger inner wing and all is well.
	Threads: 136
11
		Nice on.  Just had a read through jimbos thread and read it about the clocks.
More straight forward than I thought
	Threads: 122
9
		I wil admit i had to ask jj0063 a few questions before i did mine, but its very straightforward and easy tbh
