Would these wheels fit
17x7"
ET: 38
center bore: 65mm
You'd need 20mm spacers, assuming the stud pattern is correct. Bore is technically 65.1, but that shouldn't make any difference
[Image: sigcopy-1.jpg]
That sounds like Ford fitment, similar to what my old OZs were but in 16". 20mm spacers minimum, mine were on 26mm...
[Image: Sig500x130.png]
Ford centre bore is bigger than that though? 76mm comes to mind?
How much do spacers cost on average? And how safe are they I tend to do a lot of millege as I'm always up and down the country so I want my car to be safe
Ford centre bore is smaller, pug is 65.1mm and Ford is 63.4 ish
But the Et 38 offset is more like Ford.
