Hi All
Ive been building my 205 for the past year and a half(yet to upload my project thread,possible over xmas
Its main purpose is for weekend blasts
Its currently running a 1.8 d turbo box.
Which is shorter than a dturbo box(which I also have)
Im not sure which box to use.
Short box is fun on back roads, however I havent really got to drive it much with the 1.8 box due to the h/g (which is blown)
Is the d turbo box the same except for a longer fifth or are all the gears longer?
Personally, I think the 205 TD box has closer ratios than the 306 box. I have no facts to back this up though. Just felt better, might be the weight of the car?
I am going to keep my 205 box on when I XUD9 it.
Stick the 306 dt box on.
Personally I'd put the hdi box on as I find the 306 dt box too short
they are definatly shorter, I ve had a couple of 306 d turbos, ratios are longer
Also,just to add, the lda pin will be modded,gov mod, around 25psi on a t2, aiming for 140bhp.
Be lucky to get 140 with that turbo TBH.
It will be more efficient to run a bigger turbo with lower intake temps and not have to change the turbo all the time 'cos it is always being run out of its comfort zone.
Plenty of better turbos out there than a T2 that can be bought and fitted for not a lot of money.
I used the standard Td box and then fitted a HDI, I think Hdi was much better. iv got a set of clocks with rev counter if your needing some
My 205 was on a T2 and 30psi, hit 150 something bhp... and it's not unheard of people getting similar
Used a 306 box, but it does put a lot of strain on the engine when it starts pushing 60/70mph. Mine used to rev it's nuts off when on the motorway, stick to B roads and it's amazing fun!
I got a 306 dturbo box on atm the rpm's are quite high at 70. I want a hdi box on mine
306td box was 3k at 70mph in 5th? if I remember correctly.
Or that could have been my dw8 306?
is they flywheel on the 1.8 dturbo the same as the 1.9?
Would the clutch and release bearing that's installed on my current xud9 (1.8 box) work with the 1.9 box?
(22-12-2014, 01:57 PM)pugtk Wrote: [ -> ]is they flywheel on the 1.8 dturbo the same as the 1.9?
One is a push and one is a pull clutch I'm sure easy to swap about
I believe the 205 dt flywheel and clutch us 200mm and the 306 dt is 215mm
Interesting.
I have just bought a 205 XUD7 friction plate.
Listed for XUD7/9 and it is 215mm.
