08-07-2013, 05:22 PM
08-07-2013, 05:31 PM
M10 x 1.25 not a regular 1.5 thread. If thats the original stud that is
08-07-2013, 06:10 PM
Any idea where I can get a couple apart from eBay because you have to but a pricey pack
08-07-2013, 06:12 PM
Ummm you could try Halfords and B&Q's??
08-07-2013, 06:28 PM
i used to live in wycombe, and always used bee-fast fasteners, in cressex industrial estate, for that kind of thing. they'll probley just give you them for free
08-07-2013, 06:40 PM
Thanks for the help tom and ryan!!
While I got the thread open I might as well clear up two things
Will I need to blank this as I took the wastegate actuator off and weld it shut
The other thing was what are these for as it already has a oil feed on the left side and return/drain on the right side (opposite)
08-07-2013, 06:59 PM
Yes blank that if it the gates welded and those are the water cooling holes so ignore them lol
08-07-2013, 07:07 PM
(08-07-2013, 06:59 PM)strictly_derv Wrote: [ -> ]Yes blank that if it the gates welded and those are the water cooling holes so ignore them lol
Whats a good or easy way to blank it if you have little tools?? Ahh yes I remember forgot about the watercooling
Cheers
08-07-2013, 09:08 PM
cut an inch of tubing. put one end over the pipe and zip tie/clamp a bolt in the open end, that normally works
or just squash the pipe (might not seal 100% tho)
and/or use chemical metal i the hole
09-07-2013, 06:46 AM
I got bolts for the studs from ebay, 6 for not much at all.
You do need to seal that hole up, I used instant gasket in mine, then a small piece of hose with instant gasket to make sure it was sealed.
Are you going to be using any gaskets?
09-07-2013, 07:08 AM
Holts firegum exhaust paste. f*ck gaskets for a laugh. I never blocked my waterholes just left them.
09-07-2013, 07:47 AM
(09-07-2013, 07:08 AM)Tom Wrote: [ -> ]Holts firegum exhaust paste. f*ck gaskets for a laugh. I never blocked my waterholes just left them.
I used that and gaskets. Got a sheet of metal gasket material from eBay and cut my own.
09-07-2013, 09:31 AM
I brought a gasket for the t2 manifold where it goes onto the engine but the turbo itself and all the plates - I was just planning on using holts exhaust paste as I've heard it seals a treat
I'll try putting some on the small turbo pipe and capping it off with a small silicone hose, cheers
09-07-2013, 06:36 PM
(09-07-2013, 09:31 AM)scottbmxer Wrote: [ -> ]I brought a gasket for the t2 manifold where it goes onto the engine but the turbo itself and all the plates - I was just planning on using holts exhaust paste as I've heard it seals a treat
I did both so I was sure it was sealed, didn't want to take it off again.
