14-01-2013, 06:45 AM
Hi. How many lockiing points is there in a bosch pulley? Can't get timing belt on after a pump change from lucas?
bosch pump timing
14-01-2013, 10:41 AM
2 locking points mate, 1 @ 12 o'clock 1 @ 4 o'clock
14-01-2013, 02:59 PM
Cheers pal! Couldn't get timming belt on after a pump change!
14-01-2013, 04:49 PM
Is the tensioner in its slackest position and locked there. Make sure you put the belt on in this order: water pump, crank idler, pump, cam then tensioner last. This way all the slack is at the tensioner making it easier to get on and less likely for the timing to be out when you have finished.
17-01-2013, 10:07 AM
Thanks got sorted!
Slack in bosch pump? | dt_ | 14 | 3,541 |
21-10-2020, 03:41 AM Last Post: dt_ |
Bosch pump help for newbie | PugRy | 2 | 2,021 |
05-01-2020, 09:09 PM Last Post: jamie182 |
Lucas pump timing probe issues | weka | 0 | 1,308 |
21-03-2019, 08:39 PM Last Post: weka |
