diesel leak
diesel leak
Wink
Hi my d turbo seems to have a diesel leak but a dunno where its coming from and it seems to be worse when a park on a bank (facing upwords) is there common faults with the pump of will a just have to have a good look at all the pipes etc ? The pump seems to have diesel all over it aswell but can't seem to see any split pipes or leaking ones any help would be appriciated
could be the leak off pipes. take the intercooler off and have a good look. its common for them to leak and thats where i would start as its easy
Where are the leak off pipes ?? Are they what join to each other on top of the glow plugs ???
the little pipes that go from 1 injector to the next. little black pipes
What pump is it could be the seals gone on the pump which is quite common.
Bye Bye D-Turbo
Had to ring the AA because it wouldn't start it turns out it was the seals in the pump causing an air lock in the fuel system every time a go to start it a need to bleed the system so a need a new pump just what a needed just before Xmas!!
just get a seal kit in ebay and rebuild...
if its a bosch pump...I have one for sale...very good condition, completely unmolested... ready to send snd be fitted Smile
Me mate had a spare pump there its a Lucas one tho but am not really bothered long as a get me car sorted 65 quid to fit it so not too bad
  diesel pump leak callumh121 3 1,127 08-04-2016, 11:10 AM
Last Post: callumh121
  Leak of Pipe Air Leak PaddyPug 5 2,890 18-09-2013, 08:31 AM
Last Post: PaddyPug
Thumbs Down Diesel leak DragonRacer 4 1,443 06-08-2013, 11:53 AM
Last Post: DragonRacer
