Threads: 31
4
Car Model/Spec: tu5 bitza/cherry dt
Given 5 thank(s) in 5 post(s)
is it no heat or no blowers?
Threads: 183
20
Given 8 thank(s) in 8 post(s)
Do they blow? If not either motor or control panel. First thing I'd try your working control panel.
Threads: 591
54
Are the heater matrix pipes getting warm/hot?
Threads: 591
54
Get the blower to work be a big help...
But it concerns me that the temp gauge says 0!!
Threads: 448
51
If no heat atall then it's the matrix gone, if not blow (inb4samass) then it will probably be the blower motor
Threads: 14
7
or the headgasket's gone pop and is pressurising the coolant causing an airlock.
My phase 1 had the same problem last winter - awesome fun!
Threads: 94
7
Car Model/Spec: 205 coming soon
Yea what matt said he must be a pro now he owns one after shagging the rallye
Official Team Go-NAD fan club
Threads: 11
5
Given 2 thank(s) in 2 post(s)
06-12-2012, 03:48 PM
(This post was last modified: 06-12-2012, 05:32 PM by vincent1.)
as above with the temp gauge not reading either try putting a new thermostat in and bleeding the coolant system.
Threads: 541
124
That or check the sensor is plugged in and working for the gauge cos in this weather even with no stat they will heat up eventually.
Think its about 40-50 you see it start moving and so if you know the car has warmed up (feel the matrix hoses) then the sensor is fooked.
I reckon if the matrix pipes are getting hot then sort the blower however I do think there is strong potential for a f*cked head gasket though
Threads: 18
1
Car Model/Spec: Ph1 Sigma DT
When its warm try squeezing the top rad hose see if its solid, my pal had a 1.9 swapped his diesel laguna for it they didnt even bother checking the laguna, he came to show me and asked why its idling rough and chucking out little puffs of white smoke went n saw him the next day i undone the top pipe and there was no thermostat he was screwing when i told him hg failiure :p
Threads: 183
20
My temp guage never goes over 70? But I've took rad cap off and the water isn't dead hot. So what's that?
Threads: 31
4
dodgy sensor, outa spec resistance
Threads: 14
7
or the thermostat has been removed by someone.
Mine does the same, but give it a bootfull and it quickly rises.
I also heats up abit quicker, so it's staying unchanged over the winter.
Threads: 29
Car Model/Spec: ph1 sigma d turbo!!
Haven't posted on here in ages and thank you for all the info in the end my bro did not keep the car anyway and I just wanted to say once again thank you
Threads: 87
48
haha epic thread revival dude! how you doing? . .
