27-11-2012, 10:04 AM
How long of wheel studs do you need to fit 20mm spacers...with Cyclones...thanks
wheel bolts..(advice)
27-11-2012, 10:10 AM
20mm longer than standard . . . . . . . . unless they're hubcentric i guess . . . .
27-11-2012, 10:11 AM
27-11-2012, 10:22 AM
Hub centric spcaers basically immitate the hub so it has the same lip in the centre so the wheel sits central!
It depend on the spacers you have there are bolt on ones which bolt onto the hub and then original wheel bolts into spacer or the ones you need longer bolts for, should have really bought a kit complete with extended bolts, i got a kit with longer bolts and tapered adaptors so can use on cyclones or aftermarket wheels so saves buying new bolts when running track wheels for a start you need flat faced bolts and as matt said if using 20mm spacers they need to be 20mm longer LOL
27-11-2012, 10:23 AM
(27-11-2012, 10:11 AM)Lisa306 Wrote:(27-11-2012, 10:10 AM)Mattcheese31 Wrote: 20mm longer than standard . . . . . . . . unless they're hubcentric i guess . . . .the spacers are hub centric....that is y I am not sure? well then don't they bolt to the hub? so is it not normal size bolts? . . . .i don't know 100% to be fair as i've never used them . .
27-11-2012, 10:32 AM
I didn't know only xuds have wheel bolts
27-11-2012, 10:33 AM
(27-11-2012, 10:23 AM)Mattcheese31 Wrote:No they don't bolt straight on..I have the other ones that wheel bolts go through....Dam didn't know you could get kit...wish I had of,oh well live and learn..(27-11-2012, 10:11 AM)Lisa306 Wrote:(27-11-2012, 10:10 AM)Mattcheese31 Wrote: 20mm longer than standard . . . . . . . . unless they're hubcentric i guess . . . .the spacers are hub centric....that is y I am not sure?
27-11-2012, 10:48 AM
(This post was last modified: 27-11-2012, 10:49 AM by Pompey306mark.)
What wheels are you using with the spacers?
Just seen cyclones. They will sit further out but not beyond the arches. I did the same with my cyclones looks good. So just do it.
They won't stick out, but will need some slight arch rolling
im picking mates arch roller up this weekend and going mad on it as not arse about paintwork as getting a nice respray in new year when weather pics up
I duno if they stick out yet as i havent fitted them btw but follow what marks said
27-11-2012, 11:03 AM
Ps mine did not rub on the arches but I think in the past I had the lip rolled on my car. But no arch flaring.
You can actually pull the arches with your bare hands just to give them that little bit more of a clearance.
27-11-2012, 11:16 AM
27-11-2012, 12:02 PM
Any one got picture of 15s with 20mm spacers and arch rolled???
27-11-2012, 12:08 PM
If you look at my project thread, I have 16's with rolled arches. Or go back a load of pages and you will see cyclones with 20mm but not rolled.
Alloy Wheel Bolts | rdstars | 2 | 1,353 |
16-03-2017, 05:01 PM Last Post: rdstars |
Wheel bolts | PugRory | 11 | 2,695 |
09-11-2015, 11:55 AM Last Post: PugRory |
c5 steel/alloy wheel bolts | Poodle | 8 | 2,656 |
20-04-2015, 08:42 PM Last Post: Poodle |
