05-09-2012, 10:31 PM
hey guys. At the moment ive got a standard gti6 backbox and a home made straight through pipe which is blowing at both ends and at the welds in the centre.
http://www.ebay.co.uk/itm/Peugeot-306-2-...3f1beec538
It sounds pretty good at present with a decat and straight through centre section but with the sportex back box will it make it too noisy? Or will it be quieter once the blowing in 4 places is stopped. I presume itll stop the noise in the centre and put more out of the back box. The centre pipe with silencer is about £40 more which makes it a bit more than what i want to spend!
Also that listing is for 2.0 models but i presume it will fit the 1.8 as my current box has the same hangars? Im pretty sure the 6 and 1.8 have the same centre pipe and its only the cats that are different lengths? Also how does it work as the tip seems to come out at an angle. Does it stick out at an angle in real life or does it come out at the normal angle? D:
Thanks
Sam
Thanks
Sam
