Threads: 448
51
Right since we did the engine on my car it keeps stalling.
When ever I drop the clutch no matter how fast or slow I'm going it cuts out. Thought it was the icv, replaced lasted half a day before it started doing it again, so don't know wether that sorted it or not. It's been a temperamental problem, not sure what causes it, seems to happen more when it's hot, or been ragging.
What can I change? What sensors might cause this?
Threads: 581
195
New icv? EBay one or proper one? And did you reset the ECU at the same time?
Threads: 448
51
It was the icv of the gti mani that I had on the xsi, was working when it came off. Even gave it a clean up. Exactly the same fault. Yeah ecu reset done as it wouldn't even start lol
Threads: 289
92
Car Model/Spec: Phase 17 R26
Given 1 thank(s) in 1 post(s)
You sure that you've plugged everything back in and haven't done an Ed?
Threads: 448
51
I didn't plug things in, grant/Niall did.....
Although knowing there trolling antics wouldn't surprise me if they left something unplugged on purpose
Threads: 289
92
Nah they'd have plugged it all in. Didn't you change the inlet mani though? Double check all the sensors are plugged in first, it might be playing up because of that.
Threads: 581
195
(23-08-2012, 06:57 PM)Matt Wrote: I didn't plug things in, grant/Niall did.....
f*ck you wide boy! Spent all of my time helping to get trolled!
But if I had thought about it, I would of trolled you.
Threads: 448
51
Haven't changed my inlet mani over yet.
Also while Im thinking about it my powersteering is heavy too, could this be linked? Like aux belt bit loose? Not powering the pas pump? Causing stalling? I dunno clutching at straws I guess
Threads: 63
26
Car Model/Spec: GTi6
Given 0 thank(s) in 0 post(s)
(23-08-2012, 07:09 PM)Matt Wrote: Haven't changed my inlet mani over yet.
I assume you've actually checked the fluid? Mine was proper heavy, forgot we'd only put 1L in just to prevent it from dying.
Threads: 581
195
Matt power steering on gti/rallye is heavier than the other XU engines.
Threads: 448
51
Is it? It kinda feels like it kicks in then slowly gives up
Threads: 581
195
Checked level? Tvh unless you have a leak or a broken pump, which you would know because they sound horrendous, there's not much that can go wrong.
Threads: 448
51
Will check the level later, that doesn't corncern me as much as the stalling
Threads: 198
135
Blue power steering sensor..?
Threads: 8
0
gearbox earth poor connection? gearbox earth too close/ caught with your clutch cable?
Threads: 198
135
Threads: 115
26
Car Model/Spec: 306
Any lights on the dash when it stalls mate?
Threads: 448
51
23-08-2012, 08:45 PM
(This post was last modified: 23-08-2012, 08:48 PM by Matt.)
Hmm havent checked the earths. Will do that!
Although I've just been driving if Im hooning, come to a junction around 3.5k drop the clutch it stalls, although if I come to a junction and ease it down to 1.5k and drop the clutch it's fine :/ wtaf!
Yeah all the lights come up when it stalls lol
Threads: 581
195
It's icv. Almost 99% sure it is
Threads: 448
51
But it just been changed for a working one? And it happened after we did the engine, was absolutely fine before? How can this be killing icvs lol
Threads: 581
195
Two things. Firstly how do you know it's working? Even if it was brand new in sealed Peugeot packaging, would you assume it works fine? I certainly wouldn't.
Secondly, did you reset the ECU and are you sure you plugged it in properly? The rubber seal on the plug can become dislodged and mean it doesn't make a connection and barely clips in.
You also said you took it apart and cleaned it? How and what with? There very delicate (read crap) so wouldn't supprise me if you've made things worse!
Threads: 448
51
It ran on the xsi for 6 months without a problem, did an ecu reset but might do it again. I opened it up, cleaned the soot off with brake cleaner, might take it off and get new o rings. Beginning to annoy me all this stalling!
Threads: 541
124
Defo sounds like ICV mate.
Threads: 448
51
Temperamental piece of shit!!
Threads: 22
5
Car Model/Spec: Bmw e36 328i coupe
I would of said ICV but as some one said above try uplugging the blue connector off the powersteering pipe just behind rad has been known to cause random mistorey faults!!!
