Threads: 55
17
Car Model/Spec: 406 V6
You can get steel locking nuts, the threads are deformed slightly, you should be able to feel the drag from the locking element when you wind the nut on the thread.
Threads: 8
^^this^^
wouldnt hurt to use a bit of threadlock too
Threads: 18
2
Car Model/Spec: '95 xld .. Boosted!
(14-08-2012, 07:05 PM)Rippthrough Wrote: You can get steel locking nuts, the threads are deformed slightly, you should be able to feel the drag from the locking element when you wind the nut on the thread.
You learn something new everyday!
Threads: 136
2
Car Model/Spec: Phase 2 Dturbo
Given 1 thank(s) in 1 post(s)
On the steel locking nuts they have two cut outs at the top don't they?
Threads: 55
17
Depends, there's many different types, some are just slightly oval at the top, some have the 2 cutouts, some have the entire thread slightly triangular instead of round, some have fancy thread forms, etc.
Threads: 25
As in steel locking nuts do you mean there is no need for the nyloc part on the nut?
when replacing them in the future will i have to get just new nuts or all the bolts aswell?
I did feel the nut being quite tight to when i was starting them onto the bolts
Threads: 55
17
Yeah, no need for the nyloc bit, they are reusable a few times the steel ones without replacing them.
