Anyone rebuilding a beam/changing rear mounts?
Due to pugs some what silly minimum bag quantity, I'll have to be ordering excess of some items and was wondering if any of you would be interested in these at cost price.
Items *'ed will be purchesed regardless as they are needed. The otheres will be if there's enough intrest to make it worth it, as I don't fancy buying 20 washers to use 2.
Rear beam mount, outside washer, 2 requ, bag 20, 9 sets of these @ £1.44
Upper rear shock washers, 4 requ, bag 20, 4 sets @ £1.40
Lower rear shock washers, 2 requ, bag 10, 4 sets @ £1.30
Arb end plate bolt, 2 requ, bag 10, 4 sets @ £1.80
*Arb end plate seal 2 requ, bag 5, 1 set @ £6.76 - can order a second bag for a extra 3 sets
Torsion bar 13mm 1/2 nut, 2 requ, bag 20, 9 sets @ £1.24
*Beam tube bearing seal (item list no 12 on service box, part no 515410) 2 requ, bag 4, 1set @ £7.32
Please move this to the for sale section if needed.
[Image: sig.jpg]
Iirc grant, matt and Scott have it in the pipeline
I've got a spare set of beam mounts if its any use to you?
I maybe be intrested in a few of the items listed
Ginge, I'm getting a set of solid ones along with some cambered arms.
[Image: sig.jpg]
Where you getting the cambered arms from? Compbrake? How many degrees, 2?
I'd be interested in the stuff for the mounts, shocks and arb if any are going spare.
I need two of them plastic ARB end seals.
When we lowered mine last year I bought over £70 of bolts from Pug, none of the ones that hold the beam together but all the pinch bolts, strut bolts, wishbones, etc. Pretty much if it holds the suspension together I replaced. I just bought what I needed, didn't need to buy in bulk, maybe try a different dealer?
Grant, I'm getteng at least 3 deg, and getting them done by bakerbm.
Also the arb seals are the foam one between the plate and the beam tube, not the plastic bungs on the end.
Every other part I'm buying either comes in singels, or the quantity needed. Its just the washers that seem to be large qut bags. I doubt any dealer will sell them in singels unless there in stock as they'd have to order them then keep them in stock till there sold.
I've already spent £60 on some bits and there's another £200 to buy without the bits above, and the parts guy I use is spot on and normaly get me discount on everything, but there's no harm in trying to find a dealer with stock.
[Image: sig.jpg]
Have you got your solid beam mounts, I can make some for £120
[Image: 704e7db1.jpg]
No chance, not having any home brew stuff on the car, baker bm ones I'm going for.
[Image: sig.jpg]
  Rear beam wear Janne L 17 1,994 19-01-2015, 10:33 PM
Last Post: Toms306
  Any help lowering my rear beam camoturd 0 723 04-04-2014, 10:17 PM
Last Post: camoturd
  Ever wondered what a knackered rear beam looks like? aaronshort 10 3,140 31-01-2013, 12:47 AM
Last Post: Ollie
