Ph1 306 Sedan, XUD (UMK)
Thought I'd post this up just for the archives.
The sedan was bought 2022 from a pretty "interesting" character. It was pretty clear from the get go the car would need alot of work but never anticipated at the time just how much work it would need. This car would also be the cause later on for the estate being put on the back burner.
Straight away, the car needed suspension and brakes. The suspension had been lowered till the beam bearings collapsed, front coilovers had spring seats missing to get it lower and the brakes did'nt actually work at all. It was concerning that the previous owner drove it to me to drop it off and shortly after kicked off my "Ain't A Clewes Customs" campaign. If you know you know..
So at the time everything was being done on the side of the road. Xsara Vts rear beam and new ta coilovers were fitted. Rear disk conversion, full gti6 braking system with new brake line. Afterwards the interior was cleaned up with a blue xsi 5 door carpet and grip royal steering wheel.
Later on, I'd then hand spray a Ph1 "sports front bumper for the car and install black mask carrello headlights.
After this the car was driven around and enjoyed for a while. Eventually I built a stainless exhuast system and 10mm pump for the car which would later on inevitably kill the head gasket.
After killing the headgasket its safe to say things went out of control. Ended up raiding the parts bin and robbing the stuff from the estate to build up another engine.
 It came back on the road with forged rods, Gt2052s and 2.5" exhuast sytem.
To short cut a load of the build waffle, this is now the current spec on her:
Sedan Mod List
Engine:
• Xud9te
• Forged connecting rods
• Factory forged crankshaft
• Goetze piston rings
• Arp head studs
• Gt2052s + hybrid chra @26psi
• XUD11 trapdoor sump pan
• Xud7 Coolant manifold
• Xantia inlet manifold
• Custom inlet manifold spacers
• 3" into 2.5" induction system
• Twinpass front mount intercooler
• Revotec stand alone fan system
• 2.5" stainless steel exhaust system.
• Turbo Smart Actuator @22psi
• 4 Paddle custom clutch built off an LUK unit.
• GFB manual boost controller
• Custom bosch ve pump
- 6 Bladed vane pump
- 11mm Landrover head
- Dynamic timing advance spacer
- Custom Lda pin
- Machined Lda top cover
- Internal Pump pressure gauge
- Gov modded
Brakes/Suspension
• Xsara vts ph2 rear axel
• BakerBM solid beam mounts
• Rear disk conversion
• 283mm Gti6 brakes
• 23mm Gti6 Master cylinder
• Braided lines
• Mtec C hook brake disks
• 18mm hub conversion
• Powerflex black spec wishbones
• Bc Racing coilovers with custom machined mounting nuts and thrust bearings
• BakerBm adjustable topmounts converted to 18mm bearings
• Coilover covers
Exterior
• Ph1 Sports big bumper
• Ring fog lights
• 5 door Sideskirts
• Rc aerial
• Peugeot 205, Compomotive Dimma split rims
Interior
• Grip royal clear/chrome steering wheel
• Glowshift boost gauge
• Xsi blue carpet
• Fli sub
• Custom bmx grip shifter
• Custom skateboard wind ups
• Rare Oem black pillar trims
• Pov Spec Oem Seats
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
Nice!  Looks like a fairly solid shell ...a good base to be working from, and I suspect they're getting hard to find now.
