13-01-2019, 02:30 PM
Ok many of you will be familiar with big red. Shes going to the scrap yard in the sky to fund the restoration of my latest purchase.
![[Image: ed0b377285f2d00c2f7a3cb793a22bed.jpg]](https://uploads.tapatalk-cdn.com/20190113/ed0b377285f2d00c2f7a3cb793a22bed.jpg)
So on that bomb shell lets start.
![[Image: fe81dca54556a137724cbf319e09587a.jpg]](https://uploads.tapatalk-cdn.com/20190113/fe81dca54556a137724cbf319e09587a.jpg)
Biggest thing i need sold asap is block and letting it go for peanuts to budge it.
2.0 hdi 8v headstud engine £250
2.0 hdi 8v, Proffesional head work (reciept), Arp head studs, Victor reinz mls headgasket, Gates cambelt kit and water pump, Crank pulley (new oem), Alternator, Aux tensioner (new), Injectors (seated not leaking)
Hdi-tuning ecu £100
Hdi tuning unlocked ecu, single pin plug and play. Currently mapped up to stage 3. Comes with all the maps ive ran in my 6 years. Thats stage 1, 2, 2 limited torque and stage 3 all compatible for this ecu.
Gt2052v turbo kit £500
Gt2052v vnt turbo kit. Compromised of custom gearbox relocation manifold, thermostat housing with heat exchanger removed, "active" support mount, mech vane control, 2.5" downpipe, torques_uk an4 braided oil feed with block adapter, An10 braided oil return, intake adapter 70mm with 25mm rocker breather pipes
Landrover modulars 4x108 £200
Disco modular steels, pcd redrill 4x108, 30mm front spacers included. Nankang ns2 tyres (1 a tad low but legal) peugeot partner center caps
5 door 306 bucket seats £100
Custom subframes to suit either seatbelt or harness, adjuster rails, black mamba seats in size fat boy. Lower seat cushions repaired underneath with cable ties.
Powerflex wishbones £100
Powerflex black series wishbones with good 18mm ball joints, painted silver
Intercooler £80
Big 3" core twinpass intercooler, 2.25" piping to suit current setup but can be adapted easily
Vibra tech mounting kit £100
Race grad vibratech full engine mounts with baker bm lower nylon fork mount
Xxr 527 £300
Brand new gloss black still boxed! 4x108, 4x100, 15" 8j et0
Door cards £50
Custom hawaiian print door cards, liturally just wrapped these
Ph1 center tray £30
Ph1 center tray without keypad! Rare as hens teeth, carpeted bit retrimed in hawaiian
306 lowering kit £200
Spax rs adjustable coilovers with custom rose joint topmounts to suit stock turrets, gaz gold rear adjustable dampers
Glowshift Diesel dials! £100
Imported from the states, genuine diesel 30psi boost gauge, dedicated exhaust back pressure gauge, exhaust temp gauge to 900 deg c. All piping and wiring harnesses included
Fiberglass bonnet £100
Fiber glass inner and outer skinned bonnet, daft vent remived and smoothed back in, internal heat reflective tape, aerocatch bonnet catches, pins uncut but maybe bent
Gear stick £25
Metal gear links with ebay quickshit handle and kode anodised red m10x1.5 gear knob
Steering wheel kit £70
Momo adapter with mazda eunos black steering wheel and horn blank
Tegiwa harness bar £100
Pair Luke red 4 point harnesses £50
Estate suede roof lining £20
106 Quick silver grab handles £20
Diablo dash trims £20
Ph 1 top glove box £20
306 cab black sunvisors (slightly shorter) £20
Gti6 splitter £30
Carbon fiber capped wing mirrors £30
Carbon skinned 5 door fuel cap £10
Ramairpro 70mm filter £15
Battery relocation leads £20
Sent from my BLA-L09 using Tapatalk
Hdi-tuning ecu £100
Intercooler £80
Xxr 527 £300
Door cards £50
Ph1 center tray £30
Gear stick £25
Gti6 splitter £30
Still Living For The 306 ![Rofl Rofl](https://www.306oc.co.uk/forum/images/smilies/legacy/Skype/rofl.gif)
306 Ph1 Dturbo Estate
205 1.9 GTI (Rust.In.Pieces)
306 HDI Stage 3 Estate (Rust.In.Pieces)
