Threads: 1
Car Model/Spec: 306 s16
Country:
Hello, few weeks ago I brought peugeot 306 s16. It won't start..
ECU not activating fuel pump relay.
No spark in spark plugs..
ECU shows no fault codes.
Bosch mp 3.2(will write exact model tomorrow).
Maybe someone has ideas? Or maybe someone has full pinout?
I don't suppose the impact switch has been tripped or unplugged? Red button in the engine bay mounted on the left-hand strut tower. I don't know if that would affect the spark though, i'm not so strong on petrol engines.
Any history on the vehicle, has it been stood for a long time?
Threads: 1
Country:
Hello. Sorry for not writing so long.
1) I removed impact switch.
2) I bought it with this problem. Previous owner stated that car was fine and left for a year. After that engine didn't start.
I have no signal to fuel relay and no signal to ,,commutators" (ignition modules). As for injectors I will be able to test signal in few weeks. My oscillograph is in service now.. ground signals for ecu looks fine. But I don't have full circuit for +12 to ecu. And don't know if ecu powering is ok. I mean if you have full ecu pinout it would be great. I could test if all + is in place and all gnd is in place... sorry for bad english
Threads: 145
I do not know this car.
Does it have the brown double relay?
This relay powers up the fuel pump in the tank and the ecu.
Nice you have a scope, but need the info which i cannot provide but I am sure info will be on here or provided if you ask.
sorry I cannot be more help.
car stored for a year with this fault, is the ign switch working ok, passing power when its turned on?
Threads: 1
Country:
Ign key working fine. Immo code accepted green led lights up. Fuel relay brown (in other cars can be grey) is ok. If I force signal tofuel pump relay from ecu connector fuel pump works. But ecu don't give signal to fuel pump and ignition modules.. this model is quite old and I want it in original shape.. I could fit some programmable ecu or try to write epprom without immo. But I want it original... that's why I am trying to get full ecu wiring and some help. Maybe some had similar problems. all help would be appreciated if you had no starting problems without faults stored with bosch MP3.2
Threads: 145
21-01-2019, 10:08 AM
(This post was last modified: 21-01-2019, 10:13 AM by pug306driver.)
Get the exact wiring diagrams as the haynes book of lies just show "typical" wiring diagrams some of which are incorrect !
Pug wiring diagrams can be a bit difficult at first but the more you use them the easier they become to read and understand, practice makes perfect.
As said i dont know this model ( still learning about the 306 2l hdi dw10 etc ) but the double relay is first energised by the ecu which then tells a different part of the ecu thats its ok to proceed, the second part of the relay transmitting this info?? in a nutshell???
Threads: 52
Car Model/Spec: XSi 16v
Given 83 thank(s) in 81 post(s)
The GTI6 uses a different make of ECU from the S16 (& the 2 models weren't concurrent) so imagine the pin layouts aren't necessarily the same.
Threads: 145
25-01-2019, 09:55 AM
(This post was last modified: 25-01-2019, 09:55 AM by pug306driver.)
Nice bit of info, but are the 2 pin out diagrams of the loom plug that plugs into the ecu?
