Car misfiring
Car misfiring
Hi need help go a 1999 t reg stopped working wouldn’t start changed the stater motor got it going but it’s now misfiring and no power when driving any ideas thanks
Thanks everyone but it runs fine hen idle but when I drive off it loses power and when I go up hills it won’t go it slows down to a crawl thanks any ideas
(19-04-2018, 09:02 AM)Robo1321 Wrote: Hi need help go a 1999 t reg stopped working wouldn’t start changed the stater motor got it going but it’s now misfiring and no power when driving any ideas thanks
I've only experienced 2 cars mis-firing and each time they had oil in the spark plug wells worth looking there first given how easy it is
1999 - Black Rallye A/C
2002 - Silver 206 1.4 HDi LX
As it's your first post welcome along. Feel free to stick a little introduction up in the Newbies section.
Ideally you need to get it plugged in as there are lots of things that can cause a misfire. Have a read ..... http://www.aa1car.com/library/misfire.htm
Since you've been messing around changing a starter though I'd check you haven't damaged any wires to sensors & that the earths are all good.
Hi need help car is fine running on idle but no peer when I pull off or go up a hill it misfire and won’t move thanks for your help
Thanks everyone for your help sorted it but when I drive off it loses Power and won’t go plus when I go up hills it still misfire
