Threads: 1
Car Model/Spec: 306
Country:
19-02-2018, 09:57 PM
HELLO TO ALL .
i have problem with a brake to car 306 1998 1.9td.
First push pedal go to the floor and brake littel, in second push pedal go hard and hard. Vacum is working i was change tube and clean with petrol. What can be the problem : abd pump, master cylinder or booster. Waiting for answer
Sounds like air in system. Look for leaks or if something has been changed recently....it hasn't been blead properly.
Does pedal go to the floor?
Threads: 7
I have/had same issue turns out it was rear brake shoes and adjustment
Threads: 62
10
Sounds very much like air in the system. Has someone allowed the system to empty? There may be air in the abs pump, which will require you to find a loose gravel surface and make the ABS work to release the air, so that it can be bled out.
HDi Owner for 200k/9 years
It's air. Blead the system properly!
It won't be rear adjustment if pumping it fixes it
Threads: 7
Fixed mine no problem since had to pump mine but might be differnt for another that was just my problem
Needs bleading properly!!!!!!
Threads: 1
Car Model/Spec: 306
Country:
Threads: 42
28
No.
only the master can be made to fit, nothing else is worth the hassle.
have you bled the brakes properly yet?
