Threads: 371
29
Car Model/Spec: ford fiesta
So ill be doing another torsion bar soon. This will be my 103948575th one ive done now and i still dont have a bloody tool to pull the bars. I usually make a bodged up puller then heat and hit all in one hit. Is there an actual tool? I dont like slide hammers they are to violent for it imo. Any links, suggestions etc. If not ill weld up another puller and actually make a good one this time.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Threaded bar, large socket, washers n nuts - any specific tool is jus a glorified version
Threads: 127
33
Lol - pretty much hit the nail on the head there
Threads: 371
29
(24-06-2017, 07:15 PM)Cho99er5000 Wrote: I have a tool that looks like this. I bought it about 3 years ago £50 and never used it. If you what it I can bring it to pugfest for you.
Pretty much what ive migged up in the past. I think this time though i need some high grade steel. used 10.1 (i think) last time ill see if i can buy anything a bit stronger this time as ive snapped them in the past. Also im not going to pugfest
Threads: 6
Car Model/Spec: 306 hid 3 door
24-06-2017, 09:52 PM
(This post was last modified: 24-06-2017, 10:09 PM by Cho99er5000.)
I can post it. I very much think you wouldn't break this it's sold not bodge to gever properly made using a lave. Don't use a slide hammer for this. I don't want anything for it I'll never use it
Threads: 127
33
id rather break medium tensile bolts than strip the threads in the torsion bars tbh
Threads: 48
If bash doesn't want it, I'll take it pls
Threads: 371
29
Already messaged him. Saves me making one at the end of the day.
Threads: 42
28
never managed to strip the threads in a torsion bar, however have snapped quite a few studs trying to pull the torsion bars out.
these days I don't bother messing about, knock the arms off and if the torsion bar stays in use the press to ping them out.
