Suspension Setup
Suspension Setup
Hi guys, what would you recommend for suspension setup for the 1.4? Feels like i'm hard steering the titanic on roundabouts  Rofl
Gti rear torsion bars and anti roll bar, set of decent shocks on the front and xsara vts springs should see you well for cheap enough
(12-11-2016, 12:01 PM)KAIN306 Wrote: Feels like i'm hard steering the titanic on roundabouts  Rofl
WAT?!
Yeah I didn't realise how bad the body roll is on the standard setup lol
Sent from my SM-N910F using Tapatalk
WAT?!
As welsh pug says it shouldnt be that bad, id get all the joints checked as well just to be safe and also if you are running 13/14 inch wheels the trye profile is quite high that plays quite a part as well.
I could be completely exaggerating but does feel loose. Will get it on the ramps tomorrow for a check up.
Beam, Wishbones, Ball joints, Xsara VTS set up but all of that wouldn't be cheap
Ball park figure?
so...
gti bars are probably £40
xsara springs £40 second hand if you can find them
xsara/gti6 shocks £60 if you can find them
new wishbones with ball joints, pbushes etc £110 meyle HD
if you want the best kind of setup for wheels then gti6 cyclones are between £40 - 100 a set depending on condition. New decent tyres are about £55 a corner for decent 195/50/15
total... £250... then could be £300 on the wheels and tyres.
Replace the bushes and stick some new shocks on it - gti spec shocks will work even with the softer springs. gti ARB in the back if you like a bit of oversteer.
What is it like having gti shocks and standard non gti spec springs? Currently got a gti6 rear beam with solids and standard 2.0 hdi glx front shocks/springs
  Suspension Setup Help Eeyore 11 1,903 26-10-2014, 10:20 AM
Last Post: Rippthrough
  206 suspension users? Rock hard suspension HDIkyle 10 4,014 10-05-2013, 05:29 PM
Last Post: puglove
