Part Numbers
Part Numbers
Anyone have the part number for the metal clips that are bolted onto the slam guard that clip into the to of the rad to keep it in place, and also the part number for the 2 gearbox bushings for the clutch arm both for a dt, Thanks Smile
I also need these part numbers! D:
1327.34 O/s rad top clip was £3.67
1327.40 N/s rad top clip was £4.42
Older bush part numbers:
2175 21 FORK BEARING SUP BA- - WHITE - UNTIL RPO 08484
2175 20 FORK BEARING INF BA- - WHITE- UNTIL RPO 08484
Newer bush part numbers:
2175 55 SUP - SINCE RPO 08485
2175 54 INF - SINCE RPO 08485
2175 56 PROTECTOR 20,4X25,9-11 - SINCE RPO 08485
GTI6 Info
amazing. thanks Cully
Thanks cully, may sound stupid but what are the difference in the older and newer bushes?
newer type have a sleeve to accept a rubber seal/dust cover which is the 3rd part number shown, they retrofit to older cars fine.
Probably stick to the older bushes to keep this simpler. Going to be doing the clutch in the 306 soon and I'm replacing everything while I'm there (linkages oil etc). Did the belts and water pump a few months ago and found the original belt and pump with 150k on it :O belt all cracked and was that loose it had rubbed on the lower section of the engine mounting and the water pump and bugger all veins left :O So not taking any chances...
newer bushes will be fine, not sure if the older type is even available.
  Help finding seal/gasket numbers? doogle-d turbo 4 1,965 24-10-2018, 08:14 AM
Last Post: doogle-d turbo
  part numbers Daniel306 0 1,041 18-07-2012, 09:21 PM
Last Post: Daniel306
  Bosch pump part numbers Poodle 9 2,408 02-05-2012, 09:42 AM
Last Post: Ruan
