HDi 23.8mm Master Cylinder - Where from?
I'm having a lot of trouble sourcing the correct MC for HDi, which has the 23.8mm Bosch MC fitted. The MC is shagged, got pedal creep.
Ordered what I thought was the correct one from ECP abeit with 4 ports as I was going to blank two off, but turned out to be wrong (mounting holes were offset and the ports came out 90 degrees rather than 45). The correct MC with 2 ports is no longer stocked via ECP.
Tried GSF and they only stock the 22.2mm one for my car.
The part number for my MC is 4601 F7, Brakeparts no longer stock it nor do TRW.
Can someone point me in the right direction?
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
you got a phase2 xsara/berlingo mc, you need a 306/phase1 xsara.
Look at this on eBay http://www.ebay.co.uk/itm/301988209398
early 406 will fit, theyre all 23.8mm.
http://www.buycarparts.co.uk/oen/4601f7
https://www.amazon.co.uk/TRW-PMK585-Mast...rds=PMK585
Got a pic of a screwdriver for some reason.
(07-09-2016, 01:54 PM)DeeTurbo Wrote: http://www.buycarparts.co.uk/oen/4601f7
https://www.amazon.co.uk/TRW-PMK585-Mast...ds=PMgK585
According to reviews, that buycarparts website want a photo of a passport and credit card, something I cannot do due to work rules. I spotted the Amazon one and knowing my luck, a screwdriver will turn up!
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
  23mm Master Cylinder with 266mm Brakes MY95 18 4,773 16-04-2015, 01:42 PM
Last Post: MY95
  Hdi master cylinder tysonbully2k12 0 933 24-02-2015, 04:43 PM
Last Post: tysonbully2k12
  Master cylinder change? Tmcilvar 1 954 18-02-2015, 07:14 PM
Last Post: 306Dan
