Threads: 136
11
306 beam tube with brand new bearings and seals £40 collected
Roller bearing wishbones (useable) 60 collected SOLD
Rear beam solid mounts £80 posted SOLD
Brand new unused Heater matrix £20 delivered
21/2" 45' boost pipe £5 posted
Known working tps £5 delivered
076 injectors £30 posted SOLD
307hdi front brakes with ferodo ds2500 ppads (little life left in pads) £50 collected
Iso fix £20 delivered
brand new alternator less than 5k old £40 posted
rebuilt head £150 with 8 brand new valve, skimmed retc
306 hdi fuel pump £20 posted
fpr's x 3 £10 each posted
maf's x? £10 each
near brand new radiator £25 posted
306 FMIC setup straight fit to a standard hdi engine, includes all hoses/boost gauge and hoses/slim line fan £120 collected
Car Model/Spec: 306 D Turbo
What clutch you got on there fella?
Threads: 4
Car Model/Spec: HDI Bus
How old is the maf buddy and what make/model is it
Cheers
Threads: 35
Threads: 136
11
Maf is around 10-15k old
Yes but I had to chop them to fit
Threads: 70
10
Car Model/Spec: HDi Estate
Given 9 thank(s) in 9 post(s)
Interested in chopped rallye blanks if tim306td isn't, got a photo of them?
Maybe injectors too.
Threads: 35
Ahhh ok let tiger have dibs. Thanks
Threads: 0
Car Model/Spec: 2.0 306 HDI
Country:
Just wondering if you have any alloys for sale ?
cheers
Sent from my SM-T230 using Tapatalk
Threads: 136
11
Sorry guys had a lot on at home.
Bump and are people still interested in the above?
Threads: 136
11
First post updated with new items and pictures
Threads: 1
Car Model/Spec: 306 HDi Daily - MK1 Clio 172'd
Hi mate,
where are you? I'll have the steering wheel, possibly the exhaust too
Threads: 136
11
The exhaust is based near Maidenhead, so not far from Aylesbury
I'm going to delete your number off here as you won't want nuisance calls
Do you want the steering wheel posted or collect with exhaust?
There's pictures of the exhaust in my project thread
Threads: 1
(04-12-2016, 03:52 PM)Paul_13 Wrote: The exhaust is based near Maidenhead, so not far from Aylesbury
Yeah I could possibly collect, Maidenhead isnt far from me
Got any pictures of the complete exhaust? Is it 2.5" bore? with just the downward tip as I did see a pic of that. What about where it joins the downpipe? Will it ONLY fit an estate? mines a 5dr ph3
Any pics of the Steering wheel? Been after one for ages to change my really worn 4spoke one
Thanks, wasn't sure what the best way of contact was. Can't seem to do PM's on here.
Threads: 128
21
Given 41 thank(s) in 38 post(s)
(04-12-2016, 04:18 PM)HDiPeter Wrote: (04-12-2016, 03:52 PM)Paul_13 Wrote: The exhaust is based near Maidenhead, so not far from Aylesbury
just FYI, the shape itself is the same for the rear section but the estate is a little longer.
/Toseland
Threads: 136
11
Unfortunately it won't fit a hatch only an estate
Still interested in the steering wheel?
Peugeot planet... That with a laptop? All works?
Threads: 136
11
Yep it's nialls old work book, got a full cop of autodata on there also.
There's videos of it working on my project thread when I was doing injector readings
can get more pics if you want bud
Threads: 1
(04-12-2016, 08:08 PM)Paul_13 Wrote: Unfortunately it won't fit a hatch only an estate
yeah do still want the steering wheel bud, how much and when can I collect? cheers
Threads: 136
11
Steering wheel paid for
Open to sensible offers on the above
I also have a Gti6 beam tube with brand new bearings and seals, painted yellow and black £50 collected
Threads: 30
Given 4 thank(s) in 4 post(s)
20-12-2016, 09:02 AM
(This post was last modified: 20-12-2016, 09:02 AM by deggerz.)
What turbo is in there?
(08-12-2016, 09:40 PM)Paul_13 Wrote: Steering wheel paid for
Is it just the tube?
Threads: 128
21
You have a pm about the sub.
/Toseland
Threads: 136
11
I've got the beam tube with solid mounts. Pretty sure I've got the support arms for the shocks some where
Turbo setup is taken unfortunately
Threads: 3
Car Model/Spec: 306 D Turbo HDI
Country:
Do you have a bottom radiator hose for sale? Mine is the type that pushes into the rad & is held in with a wire clip, there is a smaller hose that attaches to the header tank with a similar fitting & the other end of the large hose attaches to the engine block with a jubilee clip.
Threads: 541
124
Still got the shell?
Would you have a price for the hand brake mechanism and surrounding metal back to just after where the cables exit under the car?
I have a 9" grinder so can cut it out myself if necessary.
Threads: 136
11
I have the hose. I can get out of off all needs be
Chris, unfortunately the car is right next to an old people's home so can't make noise
First lost updated
What laptop is the pp2k on?
Threads: 136
11
I'll find out tomorrow piggy unless Niall can tell you
http://306oc.co.uk/forum/showthread.php?...eot+planet
That's the original for sale thread
Threads: 101
Car Model/Spec: 306HDi 90 LX
if piggy changes his mind, can I have 2nd dibs on the Peugeot Planet setup please?
It goes, it stops (as reqd).
Hate Housework!
Threads: 136
11
Are you interested piggy?
