S16 cams
S16 cams
Recently got hold of a 306 s16 with a snapped cambelt, managed to get a second hand head for it, complete with cams.
The head is a Richard longman item which has been ported and fitted with a set of kent pt81 cams.
My question is are there any clearance issues, i know the gti6's were limited to what cams you could fit, is this the same or is there plenty of room and secondly am i going to see any gains or is it worth banging the standard ones in.
Many thanks in advance
Dan
Clearance is much better on 1.9 and 2.0 Mi16/S16 engines than on GTi-6.
However, given that you say that it has PT81 cams, does that mean that you've bought a GTi-6 head as those cams won't fit an S16 head?
Thanks given by: Dan Baines 89
(24-03-2016, 09:53 AM)powerandtorque Wrote: Clearance is much better on 1.9 and 2.0 Mi16/S16 engines than on GTi-6.
Good question ,i'm just going by what the advert said, i haven't even removed them yet to check for markings. I'm sure its an s16 head as it has individual cam carriers as opposed to a solid one on the gti6 heads.
They've made a nice job of porting it and the valves also look bigger than that of a gti-6 too.
Thanks for the reply
Dan
S16 cams are PT2001 to PT2006
sounds suspect, ad's are quite often wrong, got a link to it?
  Cams!!?? Beany58 46 8,667 05-02-2016, 03:22 PM
Last Post: fatlapit
  Which cams? Xsikid 12 2,724 22-12-2015, 06:41 AM
Last Post: Xsikid
  Uprated Cams - BHP Gains? 9Freedman9 41 8,476 10-01-2014, 03:06 PM
Last Post: THE_Liam
