81
Hi All,
So topping up radiators ive always just put in clean water. But when doing a full drain and refilling what should be done? Is it just water with antifreeze? In which case what product and in what ratio? Or is it all this red and blue coolant malarky or is that only in more modern cars?
I know you can get all the waterless coolant but id rather just be able to fill up if any issues. So essentially im looking for the standard procedure and a recommended product.
Cheers
Sam
Threads: 42
28
from a fresh fill it doesn't matter what you use, you just should not mix colours.
read the back of the container, job done.
81
okay so colours are for all cars just choose one. Quick google suggests red is the longer lasting. Im just checking with Carl what he put in the rallye.
Whats the best way to drain gunky water out of a 1.4 and rallye? isnt there a bottom bleed on the bottom left of the rad? or is it only top left? best to disconnect a pipe if possible?
And if its all gunky refill, bleed and run for a bit and drop the water several times to try and flush it all out?
Threads: 18
10
Generally speaking, blue is 2 year and red/pink is 5 year.... but the colours are not an absolute guide.
As Mei says, follow what's on the bottle - typically it's somewhere between 30% and 50% concentration depending on how low temperature you want protection to.
Should be a drain point bottom passenger side of rad... If it's an aftermarket rad they don't always have them though!
I've used rad flush with decent results before.
I tend to buy ready mixed pink coolant, saves trying to work out how much you've put in etc lol.
Threads: 42
28
pull the bottom hose off will drain most of the coolant out.
Threads: 465
114
Car Model/Spec: Vauxhall
i mixed mine with deionised water
using longlife pink stuff
Yeah deionised water/purified makes a fair difference.
Pink/red I was using...but as it usually chucks it out before 2years Ive gone with blue recently!
I flush and then use dishwasher tablets with hot water for a proper clean.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
put the pink stuff in or put the blue stuff in, mix according to instructions on back
jobs a good 'un?
come on sam
81
I think the confusion comes from that my coolant has never been red or blue... Its always just been non-coloured... Even now that Carl has fitted a new rad I don't know what's in it and it doesn't even look coloured.
Threads: 465
114
taste it is it sweet bitter is there any in there?
Coolant has never been "non coloured"
Threads: 42
28
o.e pug stuff in the older ones is a Strong blue, newer is Pink/orange.
Fair enough, not sure where the green comes from then!
