	Threads: 145
5
	Given 18 thank(s) in 17 post(s)
		19-10-2015, 09:27 AM
(This post was last modified: 19-10-2015, 09:34 AM by pug306driver.)
		gosh, It don't half look like a cd, wonderful finish on that lynx pulley......not sure what the " black" is from 4 to seven o clock, and the "ripples" from 7 to 9 o clock ???
I know what the marks on the really good finish surface are from......does one of the "gouges" contact the belt?? the one at 2 o clock which looks "sharp" sand could damage the belt ? Do any of the other butchery marks contact the belt at all ??
10k miles on a gates belt kit, I paid the extra and got a pug kit, oe parts supposed to be, but the water pump did not have the Peugeot lion and the belt was not marked Peugeot........so much for oe stuff, but they are gunna  honour the guarantee!!!!
Cant figure out where on the engine the picture relates to, belt looks "soggy" and the outer surface looks "worn", belt defo making contact on the right hand side........is a pulley tight, ei stiff to rotate and the belt is skidding and bit, any skreaching ??
you say a whirring noise ??
	Threads: 465
114
Car Model/Spec: Vauxhall
	Given 98 thank(s) in 92 post(s)
		thats an old style pulley they have anodized them now to a dark colour
if the belt is riding that hard against the pulley i suspect one of the pulleys/tensioner/waterpump is not sitting square on the block face
all needs to be cleaned and start again oh and i probably wouldn't use that pulley again
	Threads: 371
29
Car Model/Spec: ford fiesta
	Given 82 thank(s) in 82 post(s)
		Yeah get a 307 pully on it if you want a solid one. Best bet imo.
	Threads: 66
5
Car Model/Spec: 306 Estate - Ph1 Dturbo
	Given 6 thank(s) in 6 post(s)
		Update on this (just realised i never concluded the thread).
Turns out the wurring sound was my over tensioned aux belt (dont run a tensioner)
The second she threw the aux belt the noise stopped. Really should of checkes this first but every time the aux belt comes off ut has to be replaced or else it slips.....
Still Living For The 306   306 Ph1 Dturbo Estate
205 1.9 GTI (Rust.In.Pieces)
306 HDI Stage 3 Estate (Rust.In.Pieces)
	Threads: 117
119
		That's just stretch belts for you, really crap idea whoever came up with them.
	Threads: 202
58
	Given 29 thank(s) in 28 post(s)
		Why not run a slightly longer belt and a tensioner?
	Threads: 66
5
		Not possible. The tensioner dosnt even touch on the setup. Only way would be to make and add in an idler pulley
	Threads: 371
29
		I ran my hdi with just the tensioner no stretch belt. The tensioner only just touch's the belt and squeals. You have to relive a bit on the tensioner so I can go a bit further. Took mine off and zipped with a grinder. Spot on after that.
	Threads: 202
58
		^this,  it runs fine with a bit of thinking about it.
