Turbo boost hose
Turbo boost hose
Hi guys just wondering what the size of the boost hose coming the turbo is mines split and need to get a replacement before I take mine off.
43mm ID iirc?
I've just ordered a 41mm Id hose so should hopefully be able to squeeze it on lol
it's something like that, I think I measured the turbo as 43mm at the widest, and the 'common' size for the hose is 41mm, so it will be a nice tight fit.
I need to investigate some kind of 41>57mm adapter for my stage2 setup.
What setup are you using?
plumbing in for a 57mm/2.25" setup, don't plan on using 406/c5 pipes
  HDI turbo hose LewisG 0 737 02-11-2014, 05:16 PM
Last Post: LewisG
