No Dipped/Low beam not working
Question
Alright all, been a while!!
My sisters 306 is a NAD Ph1, and has been pretty much problem free when it comes to electrics Until now.
Her dipped/low beams won't work. I've checked the dim dip relay and it's fine, this was causing the problem before so I replaced the relay and it's been fine for 6 months.
Fuses are fine, the low voltage part of the Dipped beam comes on with the sidelights, but once the light switch is on II there's no dipped beam.
Any ideas?
Cheers...!
Harry.
Update, problem solved, duff relay.
  Low beam Not working joshh101 0 783 08-01-2015, 04:02 PM
Last Post: joshh101
  1 dipped beam working other side not??!!?? isn't the bulb DERVBUS 5 2,209 11-10-2013, 09:37 PM
Last Post: cully
  Dipped beam not working cwspellowe 10 3,266 27-05-2012, 11:41 AM
Last Post: Alee83
