08-05-2015, 03:44 PM
Guessing the 306 and zx use the same brake lines so something like these should fit yes?
http://www.kamracing.co.uk/car-tuning/pe...olour.html
Braided Lines for the zx
08-05-2015, 04:08 PM
(This post was last modified: 08-05-2015, 04:08 PM by zx_volcane.)
disc or drum?
some axles have two lines per side, other have 1 per side - worth having a look underneath and double checking swampy on here makes / orders lines up to spec - ive had a couple of sets off him and they were spot on or just pop into somewhere that can make up AN lines and get them to make you some sets up, easy peasy - take in old lines or let them know length and fittings on ends Thanks given by: kee616
08-05-2015, 04:19 PM
Hello
mine drums on the rear and i believe only one line to side okay thanks il have a look into it
09-05-2015, 03:33 PM
My 6 Rear beam have 4 lines (Phase 2.5) but I use the 4 Lines from Goodrich and swap the another remain 2 lines at the rear beam by metal pipe from the newer 6 beam without problems.
for the ZX and another PUG model eg. 405, 406, etc... the brake lines can be common use just difference in the length of hose.
1999 306 GTI-6 PT81 & Remapping
2000 406 SRI 2.0 Turbo 6M/T @ 1 Bar Boosted
09-05-2015, 11:31 PM
Ah okay I'm doing the brake cables soon so il have a look maybe it is 2 lines then
Thanks |
Braided Brake Lines | TommiePuglet | 0 | 1,418 |
21-09-2017, 02:10 PM Last Post: TommiePuglet |
GTI braided lines on HDI 266 Lucas | MY95 | 6 | 3,188 |
04-05-2016, 05:22 PM Last Post: Paul_13 |
