yellow fog lamp glass
Wanted: yellow fog lamp glass
Hi. As titled. Wanting yellow phase1 fog lamp glass. Will swap with clear and cash your way. Anyone have any?
Cheers.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Couldn't you buy the glass tint?
http://www.ebay.co.uk/itm/30-x-60cm-Yell...3a992c527c
Nice and cheap Wink and there are videos on youtube on how to fit
Hope that helps Big Grin
Yeh there isnt yellow glass its just yellow tint film! 99p!
Just out of curiosity though, how does the tint stand up to fog lights?
Done a bit of research and I think I'm going with stained glass window paint.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Ah, now I have heard of this... I do believe that the heat could 'crack' the paint over time though. Maybe there is someone with the knowhow on this and the paint is better than I think, but I would ask if it has high temperature resistance Wink
Proper tint spray? Ive used yellow in the past and had no problems
Ive had no problem with the yellow tint film for 3 years.... When my fog light smashed it was the tint that held it together and stopped glass going everywhere. Brushed or painted always looks inconsistent to me. Film is super easy to remove and replace and is the cheapest option.
(07-05-2015, 01:50 PM)Eeyore Wrote: Ive had no problem with the yellow tint film for 3 years.... When my fog light smashed it was the tint that held it together and stopped glass going everywhere. Brushed or painted always looks inconsistent to me. Film is super easy to remove and replace and is the cheapest option.
I second that Wink as for the paint, i was on about brush-on type...dunno about spray Confused
Is th film self adhesive and do you put it on the inside or outside? Also do you get 100% covered, around all of the bends perfectly? I wouldn't like it if not very tidy.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
If you do it correctly (guides on youtube) then you can cover the majority of the lens. It is self adhesive and I would only put it on the outside (easier and away from the more direct heat of bulb)
Thats just me though Wink
Some people use heat guns at distance...or hairdryer to form the tint around the lens Wink
Hope that helps mate
Not too worried about the heat problem, can't remember the last time I used the foglamps. Want it to look good though. I'll check the video on YouTube. Cheers.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Well the videos are just guides of how to tint but tinting is tinting Wink They helped me out with some tinting some years back, americans can be boring to listen/watch but the videos on there are informative Wink
(07-05-2015, 08:59 AM)Eeyore Wrote: Yeh there isnt yellow glass its just yellow tint film! 99p!
Yes there is. Some Ph.1s came with yellow foglights as standard.
62k Diablo Phase 1 Gti-6:
Project Thread
Use the film to do it, a more consistent look, easire to replace if it does get damaged and easier to remove if you change your mind.
I've done ph3 fogs and it's easy enough to do but easier if you take the lens off to do it. It's also easier to bend around some contours with heat from a hair dryer
  Fog light glass lense phase 3 wanted Teeharv 1 1,322 27-06-2018, 11:37 AM
  For sale: 3dr 206 o/s glass and regulator with motor HD-Aye! 3 974 14-10-2015, 07:45 PM
Last Post: HD-Aye!
  Wanted: Heated mirror glass Tom 0 869 17-02-2013, 06:59 PM
Last Post: Tom
