Lexia Software
Not sure if this sin the correct section but here goes...
I'm retro fitting cruise control to my 63 plate Citreon Berlingo. Just reading up online and I will need Lexia Software to activate it once I've fitted the switch. Is this just same as Peugeot Planet? Or if I need the Citreon Software where can I get it?
Cheers
Citroen software is normally on the same disc as the peugeot one. Its identical just with different info for the different models.
Nice one cheers!
Where can I buy it from? I'll need the lead for the laptop too.
Just search peugeot planet on eBay and see what comes up. Lots do normally Wink
Found it for around £90? With cables ect.
But it says it will only work on a 32 bit operating system! Both my laptops are 64 is there a way around this?
