20-03-2015, 03:22 PM
gti6 high rpm flat spot
20-03-2015, 05:31 PM
(20-03-2015, 10:45 AM)Midnightclub Wrote: A stock GTi6 will not hit the limiter in 6th, 100%. You'd need a massive down hill section at least! It gets bloody close though And bloody scary!!
20-03-2015, 10:37 PM
Out of curiosity what does the speed in 6th gear top out at with the standard limiter? Anyone know? A friend of mine had a 410bhp 6 until recently and I'm sure that's been over 160mph.
I hit the end of the speedo on the autobahn on a downhill. Couldn't get a totally flat section but generally around the mid 120s to 130 I think but then that's indicated speed rather than actual speed. Don't think you quite hit the limiter, just reach a point where you can't overcome all of the drag forces eg. air resistance, friction, hysteresis in the tyres etc.
22-03-2015, 11:26 PM
(04-03-2015, 10:34 PM)Niall Wrote: Yeah the power hits its peak at 4.5k and really does tail after 6.5-7 so i wouldn't worry tbh. Theres no need to rag these 6's to the red line! Shut up Niall, Yes there is.
1. Fooby's Car 2. Fooby's Hire Car(s) 3. Fooby's Company Pool Car Team Self Improvement 1. Learn to Car
23-03-2015, 07:15 AM
If you own a petrol and don't take it to the limiter what's the point
23-03-2015, 11:03 PM
(21-03-2015, 08:47 AM)RetroPug Wrote: I hit the end of the speedo on the autobahn on a downhill. Couldn't get a totally flat section but generally around the mid 120s to 130 I think but then that's indicated speed rather than actual speed. Don't think you quite hit the limiter, just reach a point where you can't overcome all of the drag forces eg. air resistance, friction, hysteresis in the tyres etc. I saw an indicated 140 in my completely standard rallye on the autobahn. Was then flashed out the way by a diesel touareg. Hit the limiter when it was a v6 at 142 on satnav, now hits top gear limiter at indicated 134, should be about 126.
P1 XSi track car
2.4 LWB T4 |
Flat spot/ miss fire on gti6 | kentiiboii | 11 | 3,366 |
21-02-2014, 12:26 PM Last Post: kentiiboii |
