Threads: 24
Car Model/Spec: Gti6 HB soooper charged
Good afternoon to my fellow peugeot fans I have a small problem with my plan. Iv got 2L 16v xsi and I have complete inlet manifold from the 6 to go on. Iv looked at the guide on here and am handy with the spanners. The guide says half a meter of 6 mm petrol pipe and half a meter of 8mm. But I can only get 9.5mm and 7mm will this be ok? Many thanks . Xsikid
Threads: 24
Coolio thank you was just in a hurry because mot is tomorrow and I was near halfrauds. Think I will wait till after mot and order from demon tweeks
Threads: 541
124
Halfords stock alot more sizes than that. Have you tried a different branch?
Threads: 591
54
motor factors.
Halfrauds suck hairy hamster tails
Threads: 541
124
They (up until 3 months ago at least) Used to stock 6, 6.5, 7, 7.5, 8, 8.5, 9, 9.5 and 10mm in injection hose in 1m coils.
Threads: 541
124
If I'd realised you were in Windsor I've still got half a meter of each left from when I did mine and decent jubilee clips.
Threads: 476
81
Car Model/Spec: 306 Rallye
Right. Top tip. There are several grades of fuel line. If you get the wrong type they will perish. I've bought the wrong stuff countless times. Check to see what grade it is. Most are only low pressure applications.
The stuff in packs at my local halfwords was over priced and the wrong grade!
Threads: 476
81
SAEJ30R9 is the grade i believe!
