Threads: 66
Car Model/Spec: 306 Estate - Ph1 Dturbo
Given 6 thank(s) in 6 post(s)
Right looking into removing the abs.
If I run the 23mm gti-6 master cylinder (2 ports with splits in line) do I require a bias valve in line to distribute the brakes correctly? Or is this automaticaly done by the master cylinder?
[attachment=20186]
Threads: 87
48
No, use the bias valve mate
Threads: 66
Is there a standard bias valve for 306's? Seen the 4 port master cylinders and assumed it was controlled by the master cylinder
Threads: 371
29
Car Model/Spec: ford fiesta
Its called rear compensator. Its on the axle
Threads: 66
If your on about the load compensator I deleted it with parts from my other 306.
Threads: 371
29
Then you really need a bias valve. I'm running no compensator ATM. Need to buy one for mine
Threads: 66
Ok fella, cheers for that.
I pressume you only run a bias to the rear lines to turn it down and tame them?
Threads: 2
Car Model/Spec: Track Prep'd 306 GTi6
The phase 1 GTi6 had the rear compensator, the phase 2/3 didn't have it as it was done by the ABS unit.
If you are taking the pipes straight to the rear (which it does sound like if you are taking the lines straight from the master cylinder) then you will have to have a bias valve somewhere. In the car allows for on the fly if your on a track and the weather get's wet. Can be under the bonnet as a fit and forget.
If you don't then you'll have 50/50 braking which will mean the back will lock up all the time
Threads: 57
Car Model/Spec: 306 s16 406 v6 Saab 93 Ttid
Given 3 thank(s) in 3 post(s)
Yes you run it in the rear line.
Where you fit it is up to you, some people fit them under the bonnet others inside the car by the handbrake
I can supply willwood knob adjust ones for a good price
Threads: 66
Thats the exact info I wanted will be under bonnet job as its a road car
Threads: 20
Car Model/Spec: gti 5 Turbo
u dont need alot to the rear
id go to a quiet open road and play with it
Threads: 66
Will prob stick it on a brake tester and have a play
Threads: 10
Car Model/Spec: moonstone 1.9 diesel
Fit one. 50/50 braking can be scary. ( tho can be fun lol)
Threads: 20
i run 10% to the rear on mine. sometimes 20
Threads: 58
i dont run a bias valve at all in my 205, never had a issue. Just try it with out before jumping the gun.
Threads: 371
29
Right so today I looked round lus new car. Phase one kingfisher green that's rust free . But has a dead axle. What I did notice is that it has no abs and no load compensator. I have full history with the car. And I mean full even headlamp bulb receipts. No rear beam change therefore its original. I thought they all had a form of compensation on them
Don't need a compensator with drums as far I as know. They're not efficient enough to need the brakeforce reducing lol.
Threads: 371
29
You sure all of mine had compenators with drums.
Did they have ABS though?
I'm pretty sure non-ABS drum 306s don't have them but I'm sure someone will be along to correct me lol.
Threads: 371
29
Some did some didn't. All had compensators. Hope someone sheds some light on this.
Threads: 66
Intresting. So could mean i havnt got to fit a bias maybe? Ngl havnt looked into it anymore as got overwealmed with sorting other niggles
Still Living For The 306
306 Ph1 Dturbo Estate
205 1.9 GTI (Rust.In.Pieces)
306 HDI Stage 3 Estate (Rust.In.Pieces)
Threads: 1
I have a standard Dturbo with rear drums from 1995 and it doesn't have ABS or rear compensator.
Threads: 42
28
22-01-2015, 07:54 PM
(This post was last modified: 22-01-2015, 07:54 PM by welshpug.)
they have inbuilt pressure limiters in the wheel cylinders, Drum ABS models have load compensators, late phase3 have EBD
drums really are as strong as a rear disc, hence the pressure limiters.
Threads: 371
29
Fair enough. That's new info for me. Least I know.
Threads: 87
48
I think it depends which rear drums you have, they fitted girling and bendix iirc, small and big, the big ones have a load compensator I believe
Threads: 66
Had a brake pipe fail the other day so gotta re-do it. Gonna do the abs delete without the bias to see if it works or not. Need to bleed the whole system again no matter what as also fitting braideds
Threads: 61
Given 6 thank(s) in 5 post(s)
If you run the brake pipes without a bias valve I would put a joiner near to where you would put the bias valve because if you need to run one it will be easier to fit it and wouldn't need to mess about as much
