Speedo not working after engine change (106)
Changed the engine in the 106 from a 1.1 to a 1.4xs but kept the 1.1 gearbox.
However the speedo now does not work. I am pretty sure i plugged it in fine and have not had the cluster out and all normal lights light up as should. No rev counter but the clock works ok. What are the chances of something coming loose while the gearbox was off? Do the driveshafts hold anything in place for the speedo i have missed?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
tugged on the cable while the engine was out? the back of the clocks doesnt really hold the cable well and can pull the cable away from it enough to not work. sometimes all you can hear is like a clicking noise as the cable tries to connect
www.prestige-auto-care.co.uk
Sad engine change /no EML jones 16 2,362 23-08-2015, 02:51 PM
Last Post: jones
  Speedo not working after pump change? HDIkyle 0 994 11-06-2013, 03:07 PM
Last Post: HDIkyle
Thumbs Down Speedo not working, phase 1 GP123 3 1,716 28-02-2013, 10:52 PM
Last Post: Harky
