Threads: 226
24
Car Model/Spec: A3 TDi
Hi guys i noticed recently like a clonk, then like a clonky rattly vibration type noise under hard acceleration would i be right to think engine mounts? And could just the bottom one on its own manage this problem or is it likely to be top aswell? Because i cant really rock the engine by hand but then the torque of it can turn the engine bit harder than me lol
Edit: could the turbo be hitting the bulkhead?
Threads: 9
Sounds like the engine mounts. I had to have a plate welded on my top engine mount as it was no longer a mount, just a hole! Get it checked quick before it rips it to bits. New mount is about £15 on ebay and you can do it yourself in under an hour if all is well.
Previous Car: Peugeot 306 XLdt (stock!), 150,000 miles (I miss this car
Threads: 29
Turbo wouldnt hit the bulkhead.
Replace your engine mounts. Start with the lower, then gearbox and then upper.
Threads: 226
24
The lower one looks pretty past it imo :/ i took the top one off and it was tight i wriggled it around and it wasnt going anywhere so i guess the top ones ok..
